Aller au contenu principal
Acer Chromebook CB5-132T-C8ZW Speakers Replacement
Ce dont vous avez besoin
  1. Acer Chromebook CB5-132T-C8ZW Speakers Replacement, Battery: étape 1, image 1 de 1
    • Remove eleven 7.2 mm screws from the bottom of the Chromebook using a JIS #1 screwdriver.
  2. Acer Chromebook CB5-132T-C8ZW Speakers Replacement: étape 2, image 1 de 2 Acer Chromebook CB5-132T-C8ZW Speakers Replacement: étape 2, image 2 de 2
    • Insert and slightly twist a plastic opening tool to separate and remove the backing of the Chromebook from the body.
    • Do not immediately remove the back from the laptop. The power strip keeps the backing attached to the rest of the laptop. Gently lift backing from the power button side and set next to the body of the laptop.
  3. Acer Chromebook CB5-132T-C8ZW Speakers Replacement: étape 3, image 1 de 2 Acer Chromebook CB5-132T-C8ZW Speakers Replacement: étape 3, image 2 de 2
    • Remove two 4.6 mm JIS # screws at each end of the battery.
  4. Acer Chromebook CB5-132T-C8ZW Speakers Replacement: étape 4, image 1 de 3 Acer Chromebook CB5-132T-C8ZW Speakers Replacement: étape 4, image 2 de 3 Acer Chromebook CB5-132T-C8ZW Speakers Replacement: étape 4, image 3 de 3
    • Carefully pull out the ribbon cable attached to the motherboard that runs wires to the battery.
    • Remove the battery.
  5. Acer Chromebook CB5-132T-C8ZW Speakers Replacement, Speakers: étape 5, image 1 de 3 Acer Chromebook CB5-132T-C8ZW Speakers Replacement, Speakers: étape 5, image 2 de 3 Acer Chromebook CB5-132T-C8ZW Speakers Replacement, Speakers: étape 5, image 3 de 3
    • Lift the speakers up using a spudger.
  6. Acer Chromebook CB5-132T-C8ZW Speakers Replacement: étape 6, image 1 de 1
    • Lift the white strip up and slide the speaker underneath.
  7. Acer Chromebook CB5-132T-C8ZW Speakers Replacement: étape 7, image 1 de 2 Acer Chromebook CB5-132T-C8ZW Speakers Replacement: étape 7, image 2 de 2
    • Slide the speaker through the black power strip.
    • A plastic spudger may be helpful to hold the power strip up.
  8. Acer Chromebook CB5-132T-C8ZW Speakers Replacement: étape 8, image 1 de 3 Acer Chromebook CB5-132T-C8ZW Speakers Replacement: étape 8, image 2 de 3 Acer Chromebook CB5-132T-C8ZW Speakers Replacement: étape 8, image 3 de 3
    Outil utilisé dans cette étape :
    J'achète
    • Remove the black tape that holds the wire in place using precision tweezers.
    • Unhook the wire from the small hooks that hold the wire in place.
  9. Acer Chromebook CB5-132T-C8ZW Speakers Replacement: étape 9, image 1 de 3 Acer Chromebook CB5-132T-C8ZW Speakers Replacement: étape 9, image 2 de 3 Acer Chromebook CB5-132T-C8ZW Speakers Replacement: étape 9, image 3 de 3
    • Disconnect the black connective piece using tweezers.
    • Lift the second speaker up using a plastic spudger tool.
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 3
30 derniers jours : 11
Total : 139
