Aller au contenu principal
Acer Iconia Tab A200 Motherboard Replacement
Ce dont vous avez besoin
  1. Acer Iconia Tab A200 Motherboard Replacement, Battery: étape 1, image 1 de 2 Acer Iconia Tab A200 Motherboard Replacement, Battery: étape 1, image 2 de 2
    • With the plastic opening tool pry open the grey plastic siding on both sides of the tablet.
  2. Acer Iconia Tab A200 Motherboard Replacement: étape 2, image 1 de 2 Acer Iconia Tab A200 Motherboard Replacement: étape 2, image 2 de 2
    • Using a Phillips #00 screwdriver remove the 4.0 mm screws on the sides of the tablet.
    • There are two screws on each side of the tablet that need to be removed before the back casing can be removed.
  3. Acer Iconia Tab A200 Motherboard Replacement: étape 3, image 1 de 2 Acer Iconia Tab A200 Motherboard Replacement: étape 3, image 2 de 2
    • Once the 4 screws have been removed use the plastic opening tool to pry open the device on the side of the device.
    • Be careful prying on the sides where you removed the screw as the plastic casing is not very strong and may break.
    • After prying open the case with the plastic opening tool carefully remove the case from the device and place the device face down on its screen.
  4. Acer Iconia Tab A200 Motherboard Replacement: étape 4, image 1 de 2 Acer Iconia Tab A200 Motherboard Replacement: étape 4, image 2 de 2
    • Using a Phillips #00 screwdriver remove the 4.0 mm screws holding the battery in place.
  5. Acer Iconia Tab A200 Motherboard Replacement: étape 5, image 1 de 2 Acer Iconia Tab A200 Motherboard Replacement: étape 5, image 2 de 2
    • Lift the battery out of the device, and disconnect the cable attached to the motherboard by pulling it out to the side not lifting it up.
  6. Acer Iconia Tab A200 Motherboard Replacement, DC Power Jack Component: étape 6, image 1 de 1
    • Using the plastic opening tool gently lift up the charging component out of its slot in the case.
  7. Acer Iconia Tab A200 Motherboard Replacement: étape 7, image 1 de 1
    • Continue to lift up the cord until it is free from the case and only attached to the motherboard.
    • You may need to continue using the plastic opening tool to lift the cord out of the case due to limited hand space.
  8. Acer Iconia Tab A200 Motherboard Replacement: étape 8, image 1 de 1
    • Disconnect the power component from the motherboard by pulling it out horizontally. Do not pull up on the cord only pull out
  9. Acer Iconia Tab A200 Motherboard Replacement, Speaker: étape 9, image 1 de 2 Acer Iconia Tab A200 Motherboard Replacement, Speaker: étape 9, image 2 de 2
    • After removing the battery use a Phillips head #00 screwdriver to remove the 3.0 mm screws holding the dual speakers in place.
  10. Acer Iconia Tab A200 Motherboard Replacement: étape 10, image 1 de 1
    • Once the screws are removed, lift up on the speakers to remove them from the case.
  11. Acer Iconia Tab A200 Motherboard Replacement: étape 11, image 1 de 1
    • Once you have removed the speakers from the case, disconnect the speakers from the motherboard by pulling the cable out horizontally. Do not pull up on the cable.
  12. Acer Iconia Tab A200 Motherboard Replacement, Microphone: étape 12, image 1 de 2 Acer Iconia Tab A200 Motherboard Replacement, Microphone: étape 12, image 2 de 2
    • Lift up on the microphone cable to lift the microphone component away from the case.
  13. Acer Iconia Tab A200 Motherboard Replacement: étape 13, image 1 de 1
    • Once the microphone has been lifted away from the case, disconnect the microphone cable from the motherboard by pulling the cable out horizontally. Do not lift up to remove.
  14. Acer Iconia Tab A200 Motherboard Replacement, Motherboard: étape 14, image 1 de 1
    • Using the plastic opening tool unplug the green cable by placing the tool under where the cable meets the plug and lifting up.
    • After unplugging the green cable remove the black tape that secures the green cable to motherboard.
    • Only unplug the end connected to the motherboard. Do not disconnect the soldered end of the cable.
  15. Acer Iconia Tab A200 Motherboard Replacement: étape 15, image 1 de 1
    • Using the plastic opening tool unplug the black cable by placing the tool under where the cable meets the plug and lift up.
  16. Acer Iconia Tab A200 Motherboard Replacement: étape 16, image 1 de 2 Acer Iconia Tab A200 Motherboard Replacement: étape 16, image 2 de 2
    • Once all cables have been disconnected from the motherboard, remove the seven remaining 3.0 mm screws with a Phillips head screwdriver size #00.
    • After the screws have been removed lift up on the motherboard to remove it from the case.
    • If you feel any pull when removing the motherboard, check to see if you did not disconnect a cable connected to the board.
Matt O'Brien
Membre depuis le 03/06/16
101 Réputation
1 tutoriel rédigé
Équipe
UMass Dartmouth, Team 5-5, Landers Spring 2016 Membre de l'équipe UMass Dartmouth, Team 5-5, Landers Spring 2016
UMASSD-LANDERS-S16S5G5
3 membres
6 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 10
Total : 755
