Aller au contenu principal
Acer Nitro 5 AN515-53-55G9 Touchpad Replacement
Ce dont vous avez besoin
  1. Acer Nitro 5 AN515-53-55G9 Touchpad Replacement, Battery: étape 1, image 1 de 3 Acer Nitro 5 AN515-53-55G9 Touchpad Replacement, Battery: étape 1, image 2 de 3 Acer Nitro 5 AN515-53-55G9 Touchpad Replacement, Battery: étape 1, image 3 de 3
    • Make sure laptop is off and unplugged before beginning replacement.
    • Flip the laptop upside down so that the bottom is facing up.
    • Identify the RAM tray on the bottom of the laptop.
  2. Acer Nitro 5 AN515-53-55G9 Touchpad Replacement: étape 2, image 1 de 3 Acer Nitro 5 AN515-53-55G9 Touchpad Replacement: étape 2, image 2 de 3 Acer Nitro 5 AN515-53-55G9 Touchpad Replacement: étape 2, image 3 de 3
    • Use the Phillips #0 screwdriver to remove the 9mm screw in the bottom left corner of the RAM tray covering.
    • Remove the RAM tray cover by prying up with a spudger.
  3. Acer Nitro 5 AN515-53-55G9 Touchpad Replacement: étape 3, image 1 de 3 Acer Nitro 5 AN515-53-55G9 Touchpad Replacement: étape 3, image 2 de 3 Acer Nitro 5 AN515-53-55G9 Touchpad Replacement: étape 3, image 3 de 3
    • Identify the Hard Drive tray to the left side of the laptop.
    • Remove screw with a #0 Philips screwdriver.
    • Lift up the Slot covering using a spunger.
  4. Acer Nitro 5 AN515-53-55G9 Touchpad Replacement: étape 4, image 1 de 1
    • Use the Phillips #0 screwdriver to remove the 9mm screws holding the back cover in place.
    • Remove the screws from the hard drive and remove it from the device.
  5. Acer Nitro 5 AN515-53-55G9 Touchpad Replacement: étape 5, image 1 de 3 Acer Nitro 5 AN515-53-55G9 Touchpad Replacement: étape 5, image 2 de 3 Acer Nitro 5 AN515-53-55G9 Touchpad Replacement: étape 5, image 3 de 3
    • Be sure you removed the hard drive. when you open the back shell and hard drive is built in this may cause damage to cable and other components.
    • Carefully remove the back shell from the device working your way around all the edges.
    • Do not forcefully try to separate the shell as you may cause harm to the shell.
  6. Acer Nitro 5 AN515-53-55G9 Touchpad Replacement: étape 6, image 1 de 2 Acer Nitro 5 AN515-53-55G9 Touchpad Replacement: étape 6, image 2 de 2
    • Removing the back shell of the computer and it will look like this.
    • The battery for the device is located at the bottom middle of the laptop at this orientation.
    One part you missed was to tell everyone that the HDD would still be attached to the back shell. I removed the shell and promptly ripped out my HDD cable. Now having to order a new cable…
    Mike Nitchie - Réponse
  7. Acer Nitro 5 AN515-53-55G9 Touchpad Replacement: étape 7, image 1 de 3 Acer Nitro 5 AN515-53-55G9 Touchpad Replacement: étape 7, image 2 de 3 Acer Nitro 5 AN515-53-55G9 Touchpad Replacement: étape 7, image 3 de 3
    • Locate the connector of the battery to the motherboard.
    • Using your fingers, slide out the connector.
  8. Acer Nitro 5 AN515-53-55G9 Touchpad Replacement: étape 8, image 1 de 1
    • Remove battery from device.
  9. Acer Nitro 5 AN515-53-55G9 Touchpad Replacement, Touchpad: étape 9, image 1 de 2 Acer Nitro 5 AN515-53-55G9 Touchpad Replacement, Touchpad: étape 9, image 2 de 2
    • Locate the Touchpad in the lower middle of the device.
    • Locate and remove the 4mm screws that hold the Touchpad in place.
  10. Acer Nitro 5 AN515-53-55G9 Touchpad Replacement: étape 10, image 1 de 3 Acer Nitro 5 AN515-53-55G9 Touchpad Replacement: étape 10, image 2 de 3 Acer Nitro 5 AN515-53-55G9 Touchpad Replacement: étape 10, image 3 de 3
    • Locate the Touchpad's connector.
    • Use a plastic spudger to pry up the small plastic clip on the connector port.
    • Gently pull the cable out of the port.
  11. Acer Nitro 5 AN515-53-55G9 Touchpad Replacement: étape 11, image 1 de 1
    • Lift up the Touchpad and remove it from the device.
6 autres ont terminé cette réparation.
Rheo Bruer
Membre depuis le 02/05/19
979 Réputation
4 tutoriels rédigés
2 commentaires
And where can I find the track pad replacement? Thanks.
xRiiad _YouTube - Réponse
You can purchase replacement trackpads online, on eBay or Amazon or many other places by simply Google searching “Acer Nitro 5 Touchpad Part”
Rheo Bruer - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 18
30 derniers jours : 58
Total : 6,066
