Introduction
Use this guide to change the battery on your Acer Predator Helios 300 (2020).
Model Number: PH3-15-53
The laptop battery is essential to provide portable usage since it keeps the laptop powered on.
You might want to replace your laptop battery if it is slow to charge or overheating. If the laptop is not charging, you might want to check if the power adapter for the battery is plugged in correctly before you replace the battery.
Before you begin the repair, power off your laptop and unplug the device from the charger.
Ce dont vous avez besoin
For optimal performance, after completing this guide, calibrate your newly installed battery.
8 autres ont terminé cette réparation.
Un commentaire
You're awesome, full stop. Thanks for this ridiculously easy to follow guide. Publishing guides should be your job.
