Introduction
If your laptop run out of battery quickly, it is possible that the battery is having some problems. In this case, you might want to replace your laptop battery. This manual shows you the steps to replace the battery!
For your safety, discharge your battery below 25% before disassembling your device. This reduces the risk of a dangerous thermal event if the battery is accidentally damaged during the repair. If your battery is swollen, take appropriate precautions.
Ce dont vous avez besoin
Remove the twelve screws on the back cover using the Phillips #1 screwdriver.
4 autres ont terminé cette réparation.
