Aller au contenu principal
Acer Spin SP513-52N Charging Port Replacement
Ce dont vous avez besoin
  1. Acer Spin SP513-52N Charging Port Replacement, Charging Port: étape 1, image 1 de 1
    • Power off your laptop before beginning disassembly and disconnect the device from the charger.
    • Use a Phillips #0 screwdriver to remove twelve 6.0 mm screws from the back panel.
  2. Acer Spin SP513-52N Charging Port Replacement: étape 2, image 1 de 2 Acer Spin SP513-52N Charging Port Replacement: étape 2, image 2 de 2
    • Use an opening tool in the seam of back case and slide it around the perimeter to release the clips securing it to the top case.
    • Remove the back case to reveal the internals of the laptop.
  3. Acer Spin SP513-52N Charging Port Replacement: étape 3, image 1 de 2 Acer Spin SP513-52N Charging Port Replacement: étape 3, image 2 de 2
    Outil utilisé dans cette étape :
    • Before replacing the charging port, unplug the internal battery from the motherboard.
    • Unplug the broken charging port from the motherboard with tweezers.
  4. Acer Spin SP513-52N Charging Port Replacement: étape 4, image 1 de 1
  5. Acer Spin SP513-52N Charging Port Replacement: étape 5, image 1 de 2 Acer Spin SP513-52N Charging Port Replacement: étape 5, image 2 de 2
    • Use tweezers to insert the new charging port securely.
  6. Acer Spin SP513-52N Charging Port Replacement: étape 6, image 1 de 1
    • Place the back case onto the laptop and press down around the edges of the perimeter.
    • You should hear the clips snap together.
  7. Acer Spin SP513-52N Charging Port Replacement: étape 7, image 1 de 1
    • Use a Phillips #0 screwdriver to fasten the twelve 6.0 mm screws back into place.
To reassemble your device, follow these instructions in reverse order. Apply new adhesive where necessary after cleaning the relevant areas with isopropyl alcohol (>90%). Take your e-waste to an R2 or e-Stewards certified recycler.
Sara Al-Shumari
Membre depuis le 01/10/21
145 Réputation
1 tutoriel rédigé
Équipe
York University, Team B-4, Allen Fall 2022 Membre de l'équipe York University, Team B-4, Allen Fall 2022
YORK-ALLEN-F22SBG4
3 membres
1 tutoriel rédigé
0Commentaires sur le guide
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 13
30 derniers jours : 60
Total : 1,563
