Aller au contenu principal
Amazon Echo Show 8 2nd Generation Power Board Replacement
Ce dont vous avez besoin
  1. Amazon Echo Show 8 2nd Generation Power Board Replacement, Rear Case: étape 1, image 1 de 3 Amazon Echo Show 8 2nd Generation Power Board Replacement, Rear Case: étape 1, image 2 de 3 Amazon Echo Show 8 2nd Generation Power Board Replacement, Rear Case: étape 1, image 3 de 3
    • Flip the device so that the rubber foot is facing up.
    • Insert a Jimmy between the rubber foot and chassis, then slide it around the perimeter until the rubber foot releases.
    • The adhesive that holds the rubber mat on may require some force to sever.
    • Remove the rubber foot.
  2. Amazon Echo Show 8 2nd Generation Power Board Replacement: étape 2, image 1 de 3 Amazon Echo Show 8 2nd Generation Power Board Replacement: étape 2, image 2 de 3 Amazon Echo Show 8 2nd Generation Power Board Replacement: étape 2, image 3 de 3
    • Use a T6 Torx screwdriver to remove the five 4.5 mm screws from the base of the device.
  3. Amazon Echo Show 8 2nd Generation Power Board Replacement: étape 3, image 1 de 3 Amazon Echo Show 8 2nd Generation Power Board Replacement: étape 3, image 2 de 3 Amazon Echo Show 8 2nd Generation Power Board Replacement: étape 3, image 3 de 3
    • Insert a Jimmy in the gap between the front and rear case.
    • Work the Jimmy around the perimeter to gently detach the rear case from the front case.
    • Separate the rear case from the front case.
    • There are 2 thin ribbon cables connecting the microphone board to the back cover. Take care not to tear or strain them as you separate the cases.
  4. Amazon Echo Show 8 2nd Generation Power Board Replacement: étape 4, image 1 de 3 Amazon Echo Show 8 2nd Generation Power Board Replacement: étape 4, image 2 de 3 Amazon Echo Show 8 2nd Generation Power Board Replacement: étape 4, image 3 de 3
    • Use a T6 Torx screwdriver to remove the four 5.2 mm screws that secure the microphone board to the rear case.
  5. Amazon Echo Show 8 2nd Generation Power Board Replacement, Power Board: étape 5, image 1 de 3 Amazon Echo Show 8 2nd Generation Power Board Replacement, Power Board: étape 5, image 2 de 3 Amazon Echo Show 8 2nd Generation Power Board Replacement, Power Board: étape 5, image 3 de 3
    • Lay the device face down with the power board facing you.
    • Use a T6 Torx screwdriver to remove the five 5.3 mm screws that secure the power board.
  6. Amazon Echo Show 8 2nd Generation Power Board Replacement: étape 6, image 1 de 3 Amazon Echo Show 8 2nd Generation Power Board Replacement: étape 6, image 2 de 3 Amazon Echo Show 8 2nd Generation Power Board Replacement: étape 6, image 3 de 3
    • Gently lift the power board out from its original position.
    • The ribbon cable is attached with adhesive to the speaker housing. Take care not to tear it when lifting the power board.
    • Use a spudger or your fingernail to flip up the black ZIF locking flap.
    • Pull the ribbon cable directly out of its port.
Micayla Muturi
Membre depuis le 02/14/24
181 Réputation
2 tutoriels rédigés
Équipe
University of Memphis, Team 1-3, Sneed Spring 2024 Membre de l'équipe University of Memphis, Team 1-3, Sneed Spring 2024
UM-SNEED-S24S1G3
3 membres
6 tutoriels rédigés
0 commentaires de tutoriel
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 10
30 derniers jours : 40
Total : 553
