Introduction
The motherboard in the Anbernic RG35xx is responsible in powering the device and various components. If your motherboard isn't functioning properly, this guide demonstrates how to disassembly the device in order to get to the motherboard.
Ce dont vous avez besoin
Remove the SD card located on the right side of the device by pushing into the SD card slot and pulling the card out.
Remove the six 1.2 mm screws that secure the back case with a 2.5 Hex Bit screwdriver.
Use your fingernails or tweezers to gently remove the battery connector from its socket.
Disconnect the red audio cable from its motherboard port by carefully pulling the connector with your index finger and thumb or with fine tip tweezers.
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
