Aller au contenu principal
Anbernic RG35XX Motherboard Replacement
Ce dont vous avez besoin
  1. Anbernic RG35XX Motherboard Replacement, Rear Case: étape 1, image 1 de 2 Anbernic RG35XX Motherboard Replacement, Rear Case: étape 1, image 2 de 2
    • Remove the SD card located on the right side of the device by pushing into the SD card slot and pulling the card out.
    • Remove the six 1.2 mm screws that secure the back case with a 2.5 Hex Bit screwdriver.
  2. Anbernic RG35XX Motherboard Replacement: étape 2, image 1 de 1
    • Insert an opening tool into the MicroSD card slot and twist it clockwise to begin releasing the rear case.
    • You'll hear "clicks" as the retaining clips release.
    • Pry around the entire perimeter until the rear case fully releases.
    • Remove the rear case.
  3. Anbernic RG35XX Motherboard Replacement, Anbernic RG35XX Battery Disconnection: étape 3, image 1 de 2 Anbernic RG35XX Motherboard Replacement, Anbernic RG35XX Battery Disconnection: étape 3, image 2 de 2
    • Use your fingernails or tweezers to gently remove the battery connector from its socket.
  4. Anbernic RG35XX Motherboard Replacement, Motherboard: étape 4, image 1 de 1
    • Disconnect the red audio cable from its motherboard port by carefully pulling the connector with your index finger and thumb or with fine tip tweezers.
  5. Anbernic RG35XX Motherboard Replacement: étape 5, image 1 de 1
    • Remove the six 1 mm Phillips screws that secure the motherboard to the case.
  6. Anbernic RG35XX Motherboard Replacement: étape 6, image 1 de 3 Anbernic RG35XX Motherboard Replacement: étape 6, image 2 de 3 Anbernic RG35XX Motherboard Replacement: étape 6, image 3 de 3
    • Flip up the black ZIF locking flap that secures the bronze ribbon cable.
    • Gently disconnect the bronze ribbon cable.
    • Lift the motherboard up and out the chassis.
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
Katie Cabrera
Membre depuis le 08/28/24
490 Réputation
4 tutoriels rédigés
Équipe
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 25
30 derniers jours : 67
Total : 177
