Aller au contenu principal
Anker SoundCore 2 Speaker Replacement
Ce dont vous avez besoin
  1. Anker SoundCore 2 Speaker Replacement, Front Panel: étape 1, image 1 de 2 Anker SoundCore 2 Speaker Replacement, Front Panel: étape 1, image 2 de 2
    • Insert a spudger between the front panel and the body of the speaker.
    • Pry around the edges of the front panel with the spudger to pry it away from the speaker body.
  2. Anker SoundCore 2 Speaker Replacement, Speaker: étape 2, image 1 de 3 Anker SoundCore 2 Speaker Replacement, Speaker: étape 2, image 2 de 3 Anker SoundCore 2 Speaker Replacement, Speaker: étape 2, image 3 de 3
    • Remove eight 10 mm screws from the speaker mount using a Phillips #0 screwdriver.
    • Insert a spudger in the gap between the speaker mount and speaker body to remove the speaker mount.
    • Use your hand to remove the speakers.
  3. Anker SoundCore 2 Speaker Replacement: étape 3, image 1 de 3 Anker SoundCore 2 Speaker Replacement: étape 3, image 2 de 3 Anker SoundCore 2 Speaker Replacement: étape 3, image 3 de 3
    • The speakers do not use wires so when replacing the speaker, make sure you align the metal prongs with the metal clips on the motherboard.
Tripp Lersch
Membre depuis le 01/14/21
402 Réputation
4 tutoriels rédigés
9 commentaires
Excellent guide, my speaker falls to the ground, and one of two speaker stops working, disassemble and verifying, was the speaker clip was loose
Renato Galindo - Réponse
Where can I buy a speaker for the repair ? Or will any sized speaker work ?
philcuchetti - Réponse
hi, did you manage to buy a replacement speaker? If yes from where pls?
jafarez -
Do someone get a new speaker? I need to buy one!
everton.euclides - Réponse
jafarez -
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 11
7 derniers jours : 31
30 derniers jours : 139
Total : 4,386
