Aller au contenu principal
Anki Vector LCD Facial Display Replacement
Ce dont vous avez besoin
  1. Anki Vector LCD Facial Display Replacement, LCD Facial Display: étape 1, image 1 de 3 Anki Vector LCD Facial Display Replacement, LCD Facial Display: étape 1, image 2 de 3 Anki Vector LCD Facial Display Replacement, LCD Facial Display: étape 1, image 3 de 3
    • Using the iFixit opening tool, insert the corner under Vector's golden side panel and lightly twist.
    • Repeat this step on the other side.
    • The panel should pop off without much force.
  2. Anki Vector LCD Facial Display Replacement: étape 2, image 1 de 3 Anki Vector LCD Facial Display Replacement: étape 2, image 2 de 3 Anki Vector LCD Facial Display Replacement: étape 2, image 3 de 3
    • Insert the corner of the square end of the spudger under the side plate above the partially visible screw.
    • Lightly turn the spudger to separate the plate from Vector's head.
    • Work the spudger around the plate until it comes off.
    • Repeat this step on the the other side.
  3. Anki Vector LCD Facial Display Replacement: étape 3, image 1 de 2 Anki Vector LCD Facial Display Replacement: étape 3, image 2 de 2
    • Using a Phillips #0 screwdriver, unscrew the two 2 mm screws on the side of Vector's head.
    • Repeat this step on the opposite side.
  4. Anki Vector LCD Facial Display Replacement: étape 4, image 1 de 2 Anki Vector LCD Facial Display Replacement: étape 4, image 2 de 2
    • Pull apart Vector's head. It should separate down the middle.
    • Remove the screen protector by gently pulling it free from the two face halves.
  5. Anki Vector LCD Facial Display Replacement: étape 5, image 1 de 3 Anki Vector LCD Facial Display Replacement: étape 5, image 2 de 3 Anki Vector LCD Facial Display Replacement: étape 5, image 3 de 3
    • Using your thumb and index finger, unplug the display from the plug in Vector's neck.
    • Pull the LCD and speaker assembly from Vector's head.
    • There is a very thin insulating rubber sheet located at the base of the screen. Be careful not to tear it when removing the display.
8 autres ont terminé cette réparation.
Shay Takei
Membre depuis le 04/16/19
1 570 Réputation
5 tutoriels rédigés
Équipe
Cal Poly, Team S2-G6, Maness Spring 2019 Membre de l'équipe Cal Poly, Team S2-G6, Maness Spring 2019
CPSU-MANESS-S19S2G6
4 membres
10 tutoriels rédigés
26 commentaires
Any idea where to get the proper displays ?
Holger Brueckner - Réponse
xenojin - Réponse
This is great information, but where can I buy the display?
Jackie Fischvogt - Réponse
yeah I can’t find it anywhere.
Joel Choi -
Does anyone have a line on display parts source?
warren williams - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 26
30 derniers jours : 71
Total : 10,826
