Aller au contenu principal
Antenna Cables Disconnection
Conditions préalables uniquement
Ce tutoriel est uniquement destiné à être utilisé comme prérequis d'autres tutoriels. Il ne se suffit pas à lui-même.
Ce dont vous avez besoin
  1. Antenna Cables Disconnection, Before you begin: étape 1, image 1 de 3 Antenna Cables Disconnection, Before you begin: étape 1, image 2 de 3 Antenna Cables Disconnection, Before you begin: étape 1, image 3 de 3
    • Before starting your repair:
    • Shut down your PlayStation and unplug all cables and accessories.
    • Remove any stands supporting your console and lay it down so the right side is facing up.
  2. Antenna Cables Disconnection, Remove the console covers: étape 2, image 1 de 3 Antenna Cables Disconnection, Remove the console covers: étape 2, image 2 de 3 Antenna Cables Disconnection, Remove the console covers: étape 2, image 3 de 3
    • Each console cover is secured with hooks along the rear edge and clips along the front edge.
    • To remove a cover, firmly pull up the front edge to release the clips.
    • You'll hear distinct "pops" as the clips release.
    • Remove the cover.
  3. Antenna Cables Disconnection: étape 3, image 1 de 3 Antenna Cables Disconnection: étape 3, image 2 de 3 Antenna Cables Disconnection: étape 3, image 3 de 3
    • Use the same process to remove the three remaining covers.
    • To reinstall a cover, place the hooks into their cutouts along the rear edge and firmly press the front edge of the cover into place to re‑engage the clips.
  4. Antenna Cables Disconnection, Remove the expansion slot cover screw: étape 4, image 1 de 2 Antenna Cables Disconnection, Remove the expansion slot cover screw: étape 4, image 2 de 2
    Outil utilisé dans cette étape :
    FixMat
    $36.95
    • Use a Phillips screwdriver to remove the 17.1 mm‑long screw securing the expansion slot cover.
  5. Antenna Cables Disconnection, Remove the expansion slot cover: étape 5, image 1 de 3 Antenna Cables Disconnection, Remove the expansion slot cover: étape 5, image 2 de 3 Antenna Cables Disconnection, Remove the expansion slot cover: étape 5, image 3 de 3
    • Use your fingers to lift the expansion slot cover near the notch by the screw hole and remove it.
  6. Antenna Cables Disconnection, Remove the fan cables cover: étape 6, image 1 de 3 Antenna Cables Disconnection, Remove the fan cables cover: étape 6, image 2 de 3 Antenna Cables Disconnection, Remove the fan cables cover: étape 6, image 3 de 3
    Tesa 61395 Tape
    $5.99
    • Use your fingers to remove the plastic cover hiding the fan cables connector.
    • The cover is secured with light adhesive.
    • During reassembly, press the piece of plastic back into place to secure it with the leftover adhesive. If it isn't sticking, use strips of double-sided tape to secure it.
  7. Antenna Cables Disconnection, Free the fan cables: étape 7, image 1 de 2 Antenna Cables Disconnection, Free the fan cables: étape 7, image 2 de 2
    • Gently pull the fan cables out from under their plastic clip on the frame.
  8. Antenna Cables Disconnection, Disconnect the fan: étape 8, image 1 de 3 Antenna Cables Disconnection, Disconnect the fan: étape 8, image 2 de 3 Antenna Cables Disconnection, Disconnect the fan: étape 8, image 3 de 3
    • Firmly grip the fan cables' white connector head and pull it straight up and out of its socket.
    • If you're having trouble, grip the cables just above the connector head, and gently pull.
    • During reassembly, align the connector over its socket and push down on the edges with the flat end of a spudger until it slides fully into its socket.
  9. Antenna Cables Disconnection, Remove the fan screws: étape 9, image 1 de 2 Antenna Cables Disconnection, Remove the fan screws: étape 9, image 2 de 2
    • Use a T8 Torx Security screwdriver to remove the four screws securing the fan:
    • One 31.7 mm‑long screw
    • Two 21.5 mm‑long screws
    • One 11.5 mm‑long screw
  10. Antenna Cables Disconnection, Remove the fan: étape 10, image 1 de 2 Antenna Cables Disconnection, Remove the fan: étape 10, image 2 de 2
    • Use your fingers to grab the fan by its vents and lift it straight up to remove it.
    • During reassembly:
    • This is a good point to clean the fan. Use a clean cloth and some compressed air to remove any dust or dirt.
    • Insert the fan so its cables are near their connector.
  11. Antenna Cables Disconnection, Peel up the tamper evident sticker: étape 11, image 1 de 2 Antenna Cables Disconnection, Peel up the tamper evident sticker: étape 11, image 2 de 2
  12. Antenna Cables Disconnection, Remove the fan grille: étape 12, image 1 de 3 Antenna Cables Disconnection, Remove the fan grille: étape 12, image 2 de 3 Antenna Cables Disconnection, Remove the fan grille: étape 12, image 3 de 3
    • Use your fingers to unclip and remove the plastic grille near the fan recess.
  13. Antenna Cables Disconnection, Remove the right‑side inner shell screws: étape 13, image 1 de 2 Antenna Cables Disconnection, Remove the right‑side inner shell screws: étape 13, image 2 de 2
    • Use a T8 Torx Security screwdriver to remove the 10 screws securing the right‑side inner shell:
    • Four 18.8 mm‑long screws
    • Two 18.6 mm‑long screws
    • Four 31.7 mm‑long screws
  14. Antenna Cables Disconnection, Remove the right‑side inner shell: étape 14, image 1 de 2 Antenna Cables Disconnection, Remove the right‑side inner shell: étape 14, image 2 de 2
    • Lift the right‑side inner shell straight up and remove it.
  15. Antenna Cables Disconnection, Disconnect the CMOS board: étape 15, image 1 de 3 Antenna Cables Disconnection, Disconnect the CMOS board: étape 15, image 2 de 3 Antenna Cables Disconnection, Disconnect the CMOS board: étape 15, image 3 de 3
    • Use a pair of angled tweezers to firmly grip the sides of the CMOS board connector, holding the tweezers as close to the connector as possible to get a good grip.
    • Pull the connector straight up and out of its socket to disconnect it.
    • If you're having trouble, try rocking the connector side-to-side to loosen it.
  16. Antenna Cables Disconnection, Remove the CMOS board: étape 16, image 1 de 3 Antenna Cables Disconnection, Remove the CMOS board: étape 16, image 2 de 3 Antenna Cables Disconnection, Remove the CMOS board: étape 16, image 3 de 3
    • Use your fingers to lift the CMOS board off the small metal nubs and pull it toward the center of your console to remove it.
    • If your new board doesn't come with a cable, transfer the original cable to your replacement board.
  17. Antenna Cables Disconnection, Disconnect the antenna cables: étape 17, image 1 de 3 Antenna Cables Disconnection, Disconnect the antenna cables: étape 17, image 2 de 3 Antenna Cables Disconnection, Disconnect the antenna cables: étape 17, image 3 de 3
    • Insert a spudger under the metal neck of one of the antenna cable's coaxial connectors and lift straight up to disconnect it.
    • Repeat the process to disconnect the other antenna cable.
    • Use the markings on the board to reconnect the antenna cables to the correct sockets—connect the blue cable to the socket marked RB and the white cable to the one marked RW.
    • To reconnect a cable, hold the metal connector head over its socket and press down with the flat end of a spudger until the connector snaps into place. Don't try to force the connector into place. If you're having trouble, reposition the connector and try again.
  18. Antenna Cables Disconnection: étape 18, image 1 de 3 Antenna Cables Disconnection: étape 18, image 2 de 3 Antenna Cables Disconnection: étape 18, image 3 de 3
    • Use the point of a spudger to flip up the small piece of white tape securing the antenna cables to the metal shield.
  19. Antenna Cables Disconnection, Move the antenna cables: étape 19, image 1 de 3 Antenna Cables Disconnection, Move the antenna cables: étape 19, image 2 de 3 Antenna Cables Disconnection, Move the antenna cables: étape 19, image 3 de 3
    • Use your fingers to de‑route the antenna cables from their clips on the metal shield.
    • Move the antenna cables over the side of your PlayStation so they're out of the way.
Ligne d'arrivée
Spencer Day
Membre depuis le 09/14/22
94 770 Réputation
662 tutoriels rédigés
Équipe
iFixit Membre de l'équipe iFixit
Staff
118 membres
19 434 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 6
