Aller au contenu principal
Apple Powerbook 5300 Battery Replacement
  1. Apple Powerbook 5300 Battery Replacement, Battery: étape 1, image 1 de 2 Apple Powerbook 5300 Battery Replacement, Battery: étape 1, image 2 de 2
    • To begin this repair process first position the Powerbook towards you with the monitor closed, also make sure the laptop is away from anything that can cause a fire, self harm, etc.
    • Press the battery removal latch located on the right side of the front panel.
    • Gently slide the battery out. Make sure you place the battery in a safe place where it can also be easily accesible
    • ALSO NOTE: The keyboard, front pane, and hard drive are connected to the laptop's logic board via a ribbon cable. Lift up slowly on each component with one hand and disconnect the ribbons from their ports on the logic board.
Alex Wineteer
Membre depuis le 04/13/11
154 Réputation
1 tutoriel rédigé
Équipe
Cal Poly, Team 25-30, Garner Spring 2011 Membre de l'équipe Cal Poly, Team 25-30, Garner Spring 2011
CPSU-GARNER-S11S25G30
4 membres
6 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 4
30 derniers jours : 10
Total : 3,145
