Aller au contenu principal
Apple Powerbook 5300 Battery Replacement
Info : Vous modifiez un tutoriel prérequis. Toutes les modifications apportées affecteront les 5 tutoriels qui comprennent cette étape.
Anglais
Français
Traduction de l’étape 1
Étape 1
Apple Powerbook 5300 Battery Replacement: étape 0, image 1 de 2 Apple Powerbook 5300 Battery Replacement: étape 0, image 2 de 2
  • To begin this repair process first position the Powerbook towards you with the monitor closed, also make sure the laptop is away from anything that can cause a fire, self harm, etc.
  • Press the battery removal latch located on the right side of the front panel.
  • Gently slide the battery out. Make sure you place the battery in a safe place where it can also be easily accesible
  • ALSO NOTE: The keyboard, front pane, and hard drive are connected to the laptop's logic board via a ribbon cable. Lift up slowly on each component with one hand and disconnect the ribbons from their ports on the logic board.
Insérez ici votre traduction
