Aller au contenu principal
Astro A50 2016 Headset Motherboard Replacement
Ce dont vous avez besoin
  1. Astro A50 2016 Headset Motherboard Replacement, Headset Speakers: étape 1, image 1 de 2 Astro A50 2016 Headset Motherboard Replacement, Headset Speakers: étape 1, image 2 de 2
    • Remove the magnetic ear pads by gently pulling up away from the head set.
  2. Astro A50 2016 Headset Motherboard Replacement: étape 2, image 1 de 1
    • Squeeze the plastic opening tool between the black plastic and foam pad on non mic side and then pry upwards to remove the felt pads covering the speaker.
  3. Astro A50 2016 Headset Motherboard Replacement: étape 3, image 1 de 1
    • Remove the four 6mm Phillips 1 screws.
  4. Astro A50 2016 Headset Motherboard Replacement: étape 4, image 1 de 1
    • Lift the speaker module up off the device.
  5. Astro A50 2016 Headset Motherboard Replacement, Headset Motherboard: étape 5, image 1 de 1
  6. Astro A50 2016 Headset Motherboard Replacement: étape 6, image 1 de 2 Astro A50 2016 Headset Motherboard Replacement: étape 6, image 2 de 2
    • Use a soldering iron to desolder the black and yellow wires from the two metal plates near the bottom of the device.
    • Use a soldering iron to desolder the 13 wires in rows along the left and bottom sides of the headset motherboard.
    • Comment souder et dessouder des connexions
  7. Astro A50 2016 Headset Motherboard Replacement: étape 7, image 1 de 1
    • Use the plastic opening tool to pry off the black tape covering the gray wires
  8. Astro A50 2016 Headset Motherboard Replacement: étape 8, image 1 de 1
    • Lift the motherboard out of the headset and gently disconnect the gray wires from the motherboard.
3 autres ont terminé cette réparation.
Brian Menard
Membre depuis le 10/01/17
306 Réputation
1 tutoriel rédigé
Équipe
Cal Poly, Team S15-G1, Livingston Fall 2017 Membre de l'équipe Cal Poly, Team S15-G1, Livingston Fall 2017
CPSU-LIVINGSTON-F17S15G1
3 membres
10 tutoriels rédigés
2 commentaires
Any chance I could get the E250336. USB board part from you guys? I need one.
Theron Miller - Réponse
I am having a very tough time finding this Part online. Thanks!
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 10
30 derniers jours : 43
Total : 4,328
