Aller au contenu principal
Asus Q524U Fan Assembly Replacement
Ce dont vous avez besoin
  1. Asus Q524U Fan Assembly Replacement, Back Panel: étape 1, image 1 de 2 Asus Q524U Fan Assembly Replacement, Back Panel: étape 1, image 2 de 2
    • Remove ten 3 mm screws using a Phillips #0 screwdriver.
  2. Asus Q524U Fan Assembly Replacement: étape 2, image 1 de 1
    • Lift up the back panel and set it to the side.
  3. Asus Q524U Fan Assembly Replacement, Battery: étape 3, image 1 de 2 Asus Q524U Fan Assembly Replacement, Battery: étape 3, image 2 de 2
    • Using your fingers, grip onto both sides of the wire harness and push it upwards.
  4. Asus Q524U Fan Assembly Replacement: étape 4, image 1 de 2 Asus Q524U Fan Assembly Replacement: étape 4, image 2 de 2
    • Remove the five 3 mm screws holding the battery in place using a Phillips #0 screwdriver.
  5. Asus Q524U Fan Assembly Replacement: étape 5, image 1 de 3 Asus Q524U Fan Assembly Replacement: étape 5, image 2 de 3 Asus Q524U Fan Assembly Replacement: étape 5, image 3 de 3
    • Tilt the small black tab up which will allow the blue tape to be slid out.
  6. Asus Q524U Fan Assembly Replacement: étape 6, image 1 de 1
    • Simply lift the battery up and out of its holding area.
  7. Asus Q524U Fan Assembly Replacement, Fan Assembly: étape 7, image 1 de 1
    • Remove the four 3 mm screws holding the fan in place using a Phillips #0 screwdriver.
  8. Asus Q524U Fan Assembly Replacement: étape 8, image 1 de 2 Asus Q524U Fan Assembly Replacement: étape 8, image 2 de 2
    • Remove five 3 mm screws holding the heat sink in place using a Phillips #0 screwdriver.
  9. Asus Q524U Fan Assembly Replacement: étape 9, image 1 de 3 Asus Q524U Fan Assembly Replacement: étape 9, image 2 de 3 Asus Q524U Fan Assembly Replacement: étape 9, image 3 de 3
    • Pull up fan connector tab by using the plastic handle.
  10. Asus Q524U Fan Assembly Replacement: étape 10, image 1 de 2 Asus Q524U Fan Assembly Replacement: étape 10, image 2 de 2
    • Unwind the cable wrapped around the fan casing.
  11. Asus Q524U Fan Assembly Replacement: étape 11, image 1 de 1
    • Disconnect the small cable from the fan.
  12. Asus Q524U Fan Assembly Replacement: étape 12, image 1 de 1
    • After all screws and cables are unsecured, lift the fan assembly out of the laptop.
Robert Stuart
Membre depuis le 03/08/23
233 Réputation
1 tutoriel rédigé
Équipe
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 3
30 derniers jours : 5
Total : 82
