Introduction
This guide will show the user how to safely remove and replace the keyboard.
Lift the rubber cover found on the bottom of the laptop.
  • Lift the rubber cover found on the bottom of the laptop.
  • Remove the 5.2 mm screw with a Phillips 1 Screwdriver.
Ajouter un commentaire
Use the nylon spudger to remove the back center panel.
  • Use the nylon spudger to remove the back center panel.
  • Use a Phillips 1 Screwdriver to remove the 5 mm screw that is located underneath the back panel.
  • Pull out the optical drive found on the side of the laptop.
  • Use a pair of tweezers to remove the top four rubber stoppers found on the bottom of the laptop.
  • Use a Phillips 1 Screwdriver to remove the top four 8.5 mm screws.
  • Use a nylon spudger to carefully pry the top back panel off.
  • While removing the top back panel, be careful not to break the four pin connector located underneath.
  • Disconnect the four-pin connector and remove the top back panel from the computer.
  • Use a Phillips 1 Screwdriver to remove the four 6.8 mm screws underneath the back panel.
  • Lift away the metal housings from each side of the laptop.
  • Use a Phillips 1 Screwdriver to remove the ten 5.2 mm screws holding the main panel in place.
  • Use a Phillips 1 Screwdriver to remove the four 5.2 mm screws underneath the center panel.
  • Use a plastic opening tool to pry the keyboard from the base of the laptop.
  • Lift the keyboard carefully so as to not tear or break the four ribbon connectors underneath the keyboard.
  • Use a pair of tweezers to undo each of the four ribbon connectors.
  • The keyboard is now completely disconnected from the laptop and you can remove it.
Aurora Rios
Membre depuis le 22/01/2018
712 Réputation
4 tutoriels rédigés
Équipe
Cal Poly, Team S16-G1, Banghart Winter 2018 Membre de l'équipe Cal Poly, Team S16-G1, Banghart Winter 2018
CPSU-BANGHART-W18S16G1
4 membres
7 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 2
7 derniers jours : 3
30 derniers jours : 17
Total : 69
