Aller au contenu principal
Asus ROG G752V Keyboard Replacement
Ce dont vous avez besoin
  1. Asus ROG G752V Keyboard Replacement, Keyboard: étape 1, image 1 de 2 Asus ROG G752V Keyboard Replacement, Keyboard: étape 1, image 2 de 2
    Outil utilisé dans cette étape :
    J'achète
    • Make sure you disconnect the charger before starting this guide.
    • Using a pair of tweezers, remove all 11 rubber plugs off of the back cover.
  2. Asus ROG G752V Keyboard Replacement: étape 2, image 1 de 2 Asus ROG G752V Keyboard Replacement: étape 2, image 2 de 2
    • Using a Phillips #0 screwdriver, remove all twelve 5.2mm screws on the back of the laptop.
    • There is one 5.2 mm screw under the rubber plug in the middle.
  3. Asus ROG G752V Keyboard Replacement: étape 3, image 1 de 1
    • Pull up the rubber seal and the service cover will come off.
  4. Asus ROG G752V Keyboard Replacement: étape 4, image 1 de 1
    • Using the Phillips #00 screwdriver, remove the six 5.2 mm screws under the service cover.
  5. Asus ROG G752V Keyboard Replacement: étape 5, image 1 de 1
    • Using your hands, pull the optical drive out.
  6. Asus ROG G752V Keyboard Replacement: étape 6, image 1 de 2 Asus ROG G752V Keyboard Replacement: étape 6, image 2 de 2
    • Use the iFixit opening tool to pry apart the back panel from the main body of the laptop.
    • Start from the front side of the laptop and then continue to the side for easier access.
  7. Asus ROG G752V Keyboard Replacement: étape 7, image 1 de 2 Asus ROG G752V Keyboard Replacement: étape 7, image 2 de 2
    • Slowly pull out the keyboard while lifting it about an inch.
    • There are cables attached to the keyboard and motherboard. DO NOT lift it more than 2 inches above the laptop.
  8. Asus ROG G752V Keyboard Replacement: étape 8, image 1 de 3 Asus ROG G752V Keyboard Replacement: étape 8, image 2 de 3 Asus ROG G752V Keyboard Replacement: étape 8, image 3 de 3
    • Using an ESD safe tool, detach all 3 ribbon cables. To do so, lift up the cable up and out.
  9. Asus ROG G752V Keyboard Replacement: étape 9, image 1 de 2 Asus ROG G752V Keyboard Replacement: étape 9, image 2 de 2
    • Once the cables are detached, lift the keyboard about 2 inches up and remove it from the rest of the body.
    • Make sure that the screen is open like the photo. This will ensure that none your laptop components will not be bent.
2 autres ont terminé cette réparation.
Jeong
Membre depuis le 09/16/19
1 149 Réputation
5 tutoriels rédigés
Un commentaire
That is not the "Keyboard" that is the entire top section or palm rest. Which also includes the touchpad and special function buttons. You should re name this as it is not accurate.
Doug Harris - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 6
7 derniers jours : 23
30 derniers jours : 63
Total : 3,613
