Aller au contenu principal
Asus Vivobook Max X541SA-PD0703X CD drive Replacement
Ce dont vous avez besoin
  1. Asus Vivobook Max X541SA-PD0703X CD drive Replacement, Hard Drive: étape 1, image 1 de 1
    • Flip the laptop upside down so that the back of the laptop faces you.
  2. Asus Vivobook Max X541SA-PD0703X CD drive Replacement: étape 2, image 1 de 1
    • Remove the following ten Phillips #0 screws from the bottom of the laptop:
    • Six 13mm screws.
    • Four 11mm screws.
  3. Asus Vivobook Max X541SA-PD0703X CD drive Replacement: étape 3, image 1 de 3 Asus Vivobook Max X541SA-PD0703X CD drive Replacement: étape 3, image 2 de 3 Asus Vivobook Max X541SA-PD0703X CD drive Replacement: étape 3, image 3 de 3
    • Using a plastic opening tool, pry up the palm rest from the bottom case of the laptop.
    • Don't completely remove as there are ribbon cables connecting the two halves.
  4. Asus Vivobook Max X541SA-PD0703X CD drive Replacement: étape 4, image 1 de 3 Asus Vivobook Max X541SA-PD0703X CD drive Replacement: étape 4, image 2 de 3 Asus Vivobook Max X541SA-PD0703X CD drive Replacement: étape 4, image 3 de 3
    • Use a spudger to flip up the retaining flaps on both keyboard ribbon cable ZIF sockets.
    • Pull the ribbon cables out of their sockets.
  5. Asus Vivobook Max X541SA-PD0703X CD drive Replacement: étape 5, image 1 de 1
    • Remove the three 6mm Phillips #0 screws from the motherboard.
  6. Asus Vivobook Max X541SA-PD0703X CD drive Replacement: étape 6, image 1 de 2 Asus Vivobook Max X541SA-PD0703X CD drive Replacement: étape 6, image 2 de 2
    • Pull the Wi-Fi card out of the motherboard.
  7. Asus Vivobook Max X541SA-PD0703X CD drive Replacement: étape 7, image 1 de 1
    • Remove the hard drive by pulling it towards the right, and removing it from the laptop case
  8. Asus Vivobook Max X541SA-PD0703X CD drive Replacement, Disc Drive: étape 8, image 1 de 1
    • Remove the disc drive by sliding it towards the right and removing it from the laptop case
Mayar Eskandarani
Membre depuis le 02/22/18
385 Réputation
2 tutoriels rédigés
Équipe
USF Tampa, Team S1-G4, Cagle Spring 2018 Membre de l'équipe USF Tampa, Team S1-G4, Cagle Spring 2018
USFT-CAGLE-S18S1G4
4 membres
7 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 3
30 derniers jours : 14
Total : 758
