Aller au contenu principal
Asus Vivobook Max X541SA-PD0703X Hard Drive Replacement
Ce dont vous avez besoin
  1. Asus Vivobook Max X541SA-PD0703X Hard Drive Replacement, Hard Drive: étape 1, image 1 de 1
    • Flip the laptop upside down so that the back of the laptop faces you.
  2. Asus Vivobook Max X541SA-PD0703X Hard Drive Replacement: étape 2, image 1 de 1
    • Remove the following ten Phillips #0 screws from the bottom of the laptop:
    • Six 13mm screws.
    • Four 11mm screws.
  3. Asus Vivobook Max X541SA-PD0703X Hard Drive Replacement: étape 3, image 1 de 3 Asus Vivobook Max X541SA-PD0703X Hard Drive Replacement: étape 3, image 2 de 3 Asus Vivobook Max X541SA-PD0703X Hard Drive Replacement: étape 3, image 3 de 3
    • Using a plastic opening tool, pry up the palm rest from the bottom case of the laptop.
    • Don't completely remove as there are ribbon cables connecting the two halves.
  4. Asus Vivobook Max X541SA-PD0703X Hard Drive Replacement: étape 4, image 1 de 3 Asus Vivobook Max X541SA-PD0703X Hard Drive Replacement: étape 4, image 2 de 3 Asus Vivobook Max X541SA-PD0703X Hard Drive Replacement: étape 4, image 3 de 3
    • Use a spudger to flip up the retaining flaps on both keyboard ribbon cable ZIF sockets.
    • Pull the ribbon cables out of their sockets.
  5. Asus Vivobook Max X541SA-PD0703X Hard Drive Replacement: étape 5, image 1 de 1
    • Remove the three 6mm Phillips #0 screws from the motherboard.
  6. Asus Vivobook Max X541SA-PD0703X Hard Drive Replacement: étape 6, image 1 de 2 Asus Vivobook Max X541SA-PD0703X Hard Drive Replacement: étape 6, image 2 de 2
    • Pull the Wi-Fi card out of the motherboard.
  7. Asus Vivobook Max X541SA-PD0703X Hard Drive Replacement: étape 7, image 1 de 1
    • Remove the hard drive by pulling it towards the right, and removing it from the laptop case
3 autres ont terminé cette réparation.
Mayar Eskandarani
Membre depuis le 02/22/18
385 Réputation
2 tutoriels rédigés
Équipe
USF Tampa, Team S1-G4, Cagle Spring 2018 Membre de l'équipe USF Tampa, Team S1-G4, Cagle Spring 2018
USFT-CAGLE-S18S1G4
4 membres
7 tutoriels rédigés
2 commentaires
is it possible to upgrade the hard drive of any laptop? from 500GB to 1T?
kevin ross s. rosento - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 1
30 derniers jours : 17
Total : 2,570
