Aller au contenu principal
Asus Vivobook Max X541SA-PD0703X Keyboard Replacement
Ce dont vous avez besoin
  1. Asus Vivobook Max X541SA-PD0703X Keyboard Replacement, Keyboard: étape 1, image 1 de 1
    • Flip the laptop upside down so that the back of the laptop faces you.
  2. Asus Vivobook Max X541SA-PD0703X Keyboard Replacement: étape 2, image 1 de 1
    • Remove the following ten Phillips #0 screws from the bottom of the laptop:
    • Six 13mm screws.
    • Four 11mm screws.
  3. Asus Vivobook Max X541SA-PD0703X Keyboard Replacement: étape 3, image 1 de 2 Asus Vivobook Max X541SA-PD0703X Keyboard Replacement: étape 3, image 2 de 2
    • Using a plastic opening tool, pry up the palm rest form the bottom half of the laptop.
    • Ribbon cables connect the two half so don't remove completely.
  4. Asus Vivobook Max X541SA-PD0703X Keyboard Replacement: étape 4, image 1 de 3 Asus Vivobook Max X541SA-PD0703X Keyboard Replacement: étape 4, image 2 de 3 Asus Vivobook Max X541SA-PD0703X Keyboard Replacement: étape 4, image 3 de 3
    • Use a spudger to flip up the retaining flap on the keyboard ribbon cable ZIF sockets.
    • Pull the ribbon cables out of their sockets.
  5. Asus Vivobook Max X541SA-PD0703X Keyboard Replacement: étape 5, image 1 de 1
    • Take the keyboard half of the laptop and place it in front of you so that they keys are facing down.
  6. Asus Vivobook Max X541SA-PD0703X Keyboard Replacement: étape 6, image 1 de 1
    • Remove the three 3mm Phillips #0 screws from the touchpad.
  7. Asus Vivobook Max X541SA-PD0703X Keyboard Replacement: étape 7, image 1 de 1
    • Use a spudger to flip up the retaining flap on the touch pad ribbon cable ZIF socket.
    • Pull the ribbon out of the socket.
  8. Asus Vivobook Max X541SA-PD0703X Keyboard Replacement: étape 8, image 1 de 2 Asus Vivobook Max X541SA-PD0703X Keyboard Replacement: étape 8, image 2 de 2
    • Remove the touchpad.
2 autres ont terminé cette réparation.
Hetvi Mehta
Membre depuis le 02/22/18
781 Réputation
5 tutoriels rédigés
Équipe
USF Tampa, Team S1-G4, Cagle Spring 2018 Membre de l'équipe USF Tampa, Team S1-G4, Cagle Spring 2018
USFT-CAGLE-S18S1G4
4 membres
7 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 2
30 derniers jours : 15
Total : 1,953
