Aller au contenu principal
Asus Vivobook Q301LA-BHI5T02 Fan and Heatsink Replacement
Ce dont vous avez besoin
  1. Asus Vivobook Q301LA-BHI5T02 Fan and Heatsink Replacement, Back Cover: étape 1, image 1 de 1
    • Make sure the computer is turned off.
    • Flip the device over so that the back cover is facing you.
  2. Asus Vivobook Q301LA-BHI5T02 Fan and Heatsink Replacement: étape 2, image 1 de 2 Asus Vivobook Q301LA-BHI5T02 Fan and Heatsink Replacement: étape 2, image 2 de 2
    • Remove the four 5mm Phillips #1 screws from the top of the laptop.
    • Remove the two 6mm Phillips #1 screws from the sides of the laptop.
    • Remove the four 2mm Phillips #1 screws from the bottom of the laptop.
  3. Asus Vivobook Q301LA-BHI5T02 Fan and Heatsink Replacement: étape 3, image 1 de 3 Asus Vivobook Q301LA-BHI5T02 Fan and Heatsink Replacement: étape 3, image 2 de 3 Asus Vivobook Q301LA-BHI5T02 Fan and Heatsink Replacement: étape 3, image 3 de 3
    • Use a plastic opening tool to gently pry the bottom of the laptop up. Slowly slide it along the edges, twisting it every so often to pop the bottom of the laptop out of the clips holding it in place.
  4. Asus Vivobook Q301LA-BHI5T02 Fan and Heatsink Replacement: étape 4, image 1 de 1
    • Lift off the cover and remove the back cover from the device.
  5. Asus Vivobook Q301LA-BHI5T02 Fan and Heatsink Replacement, Fan and Heatsink: étape 5, image 1 de 3 Asus Vivobook Q301LA-BHI5T02 Fan and Heatsink Replacement, Fan and Heatsink: étape 5, image 2 de 3 Asus Vivobook Q301LA-BHI5T02 Fan and Heatsink Replacement, Fan and Heatsink: étape 5, image 3 de 3
    • Using a Phillips #1 Screwdriver remove the three 3 mm black screws and four 2 mm copper screws holding the fan and heat sink in place.
  6. Asus Vivobook Q301LA-BHI5T02 Fan and Heatsink Replacement: étape 6, image 1 de 2 Asus Vivobook Q301LA-BHI5T02 Fan and Heatsink Replacement: étape 6, image 2 de 2
    • Remove the wire connecting the fan to the motherboard.
  7. Asus Vivobook Q301LA-BHI5T02 Fan and Heatsink Replacement: étape 7, image 1 de 2 Asus Vivobook Q301LA-BHI5T02 Fan and Heatsink Replacement: étape 7, image 2 de 2
    • Gently remove the fan and heat sink from the motherboard.
    • On reassembly, be sure to clean the CPU and heat sink and reapply thermal compound to the CPU. Follow this guide to learn how.
Royce Gunter
Membre depuis le 10/02/17
101 Réputation
1 tutoriel rédigé
Équipe
USF Tampa, Team S10-G3, Thompson Fall 2017 Membre de l'équipe USF Tampa, Team S10-G3, Thompson Fall 2017
USFT-THOMPSON-F17S10G3
4 membres
6 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 6
Total : 575
