Aller au contenu principal
Asus Vivobook Q301LA-BHI5T02 Motherboard Replacement
Ce dont vous avez besoin
  1. Asus Vivobook Q301LA-BHI5T02 Motherboard Replacement, Back Cover: étape 1, image 1 de 1
    • Make sure the computer is turned off.
    • Flip the device over so that the back cover is facing you.
  2. Asus Vivobook Q301LA-BHI5T02 Motherboard Replacement: étape 2, image 1 de 2 Asus Vivobook Q301LA-BHI5T02 Motherboard Replacement: étape 2, image 2 de 2
    • Remove the four 5mm Phillips #1 screws from the top of the laptop.
    • Remove the two 6mm Phillips #1 screws from the sides of the laptop.
    • Remove the four 2mm Phillips #1 screws from the bottom of the laptop.
  3. Asus Vivobook Q301LA-BHI5T02 Motherboard Replacement: étape 3, image 1 de 3 Asus Vivobook Q301LA-BHI5T02 Motherboard Replacement: étape 3, image 2 de 3 Asus Vivobook Q301LA-BHI5T02 Motherboard Replacement: étape 3, image 3 de 3
    • Use a plastic opening tool to gently pry the bottom of the laptop up. Slowly slide it along the edges, twisting it every so often to pop the bottom of the laptop out of the clips holding it in place.
  4. Asus Vivobook Q301LA-BHI5T02 Motherboard Replacement: étape 4, image 1 de 1
    • Lift off the cover and remove the back cover from the device.
  5. Asus Vivobook Q301LA-BHI5T02 Motherboard Replacement, Battery: étape 5, image 1 de 2 Asus Vivobook Q301LA-BHI5T02 Motherboard Replacement, Battery: étape 5, image 2 de 2
    • Using a Phillips #1 Screwdriver remove the six 3 mm screws keeping the battery in place.
  6. Asus Vivobook Q301LA-BHI5T02 Motherboard Replacement: étape 6, image 1 de 2 Asus Vivobook Q301LA-BHI5T02 Motherboard Replacement: étape 6, image 2 de 2
    • Unplug the battery connector from the mother board.
  7. Asus Vivobook Q301LA-BHI5T02 Motherboard Replacement: étape 7, image 1 de 2 Asus Vivobook Q301LA-BHI5T02 Motherboard Replacement: étape 7, image 2 de 2
    • Gently remove the battery from the slot.
  8. Asus Vivobook Q301LA-BHI5T02 Motherboard Replacement, Wifi card: étape 8, image 1 de 3 Asus Vivobook Q301LA-BHI5T02 Motherboard Replacement, Wifi card: étape 8, image 2 de 3 Asus Vivobook Q301LA-BHI5T02 Motherboard Replacement, Wifi card: étape 8, image 3 de 3
    • Unplug the two small cords connected to the wifi card.
  9. Asus Vivobook Q301LA-BHI5T02 Motherboard Replacement: étape 9, image 1 de 1
    • Using a Phillips #1 Screwdriver unscrew the 2 mm screw holding the wifi card in place.
  10. Asus Vivobook Q301LA-BHI5T02 Motherboard Replacement: étape 10, image 1 de 3 Asus Vivobook Q301LA-BHI5T02 Motherboard Replacement: étape 10, image 2 de 3 Asus Vivobook Q301LA-BHI5T02 Motherboard Replacement: étape 10, image 3 de 3
    • Unplug the Wi-Fi card from the motherboard and remove it from the device.
  11. Asus Vivobook Q301LA-BHI5T02 Motherboard Replacement, Fan and Heatsink: étape 11, image 1 de 3 Asus Vivobook Q301LA-BHI5T02 Motherboard Replacement, Fan and Heatsink: étape 11, image 2 de 3 Asus Vivobook Q301LA-BHI5T02 Motherboard Replacement, Fan and Heatsink: étape 11, image 3 de 3
    • Using a Phillips #1 Screwdriver remove the three 3 mm black screws and four 2 mm copper screws holding the fan and heat sink in place.
  12. Asus Vivobook Q301LA-BHI5T02 Motherboard Replacement: étape 12, image 1 de 2 Asus Vivobook Q301LA-BHI5T02 Motherboard Replacement: étape 12, image 2 de 2
    • Remove the wire connecting the fan to the motherboard.
  13. Asus Vivobook Q301LA-BHI5T02 Motherboard Replacement: étape 13, image 1 de 2 Asus Vivobook Q301LA-BHI5T02 Motherboard Replacement: étape 13, image 2 de 2
    • Gently remove the fan and heat sink from the motherboard.
    • On reassembly, be sure to clean the CPU and heat sink and reapply thermal compound to the CPU. Follow this guide to learn how.
  14. Asus Vivobook Q301LA-BHI5T02 Motherboard Replacement, RAM: étape 14, image 1 de 3 Asus Vivobook Q301LA-BHI5T02 Motherboard Replacement, RAM: étape 14, image 2 de 3 Asus Vivobook Q301LA-BHI5T02 Motherboard Replacement, RAM: étape 14, image 3 de 3
    • Remove the top covering the RAM chips.
  15. Asus Vivobook Q301LA-BHI5T02 Motherboard Replacement: étape 15, image 1 de 3 Asus Vivobook Q301LA-BHI5T02 Motherboard Replacement: étape 15, image 2 de 3 Asus Vivobook Q301LA-BHI5T02 Motherboard Replacement: étape 15, image 3 de 3
    • Gently push the RAM chip holder to the sides.
  16. Asus Vivobook Q301LA-BHI5T02 Motherboard Replacement: étape 16, image 1 de 3 Asus Vivobook Q301LA-BHI5T02 Motherboard Replacement: étape 16, image 2 de 3 Asus Vivobook Q301LA-BHI5T02 Motherboard Replacement: étape 16, image 3 de 3
    • Remove the RAM from the device.
  17. Asus Vivobook Q301LA-BHI5T02 Motherboard Replacement, Motherboard: étape 17, image 1 de 1
    • Remove the four 4.0 mm Phillips #1 screws shown.
    • Remove the two 5.0 mm Phillips #1 screws shown.
    • Remove the three 3.0 mm Phillips #1 screws shown.
  18. Asus Vivobook Q301LA-BHI5T02 Motherboard Replacement: étape 18, image 1 de 2 Asus Vivobook Q301LA-BHI5T02 Motherboard Replacement: étape 18, image 2 de 2
    • Using a plastic opening tool, pry open the hinge shown until your fingers can fit under it.
    • Pull the hinge the rest of the way up.
  19. Asus Vivobook Q301LA-BHI5T02 Motherboard Replacement: étape 19, image 1 de 1
    • Disconnect the motherboard from the two connectors shown.
  20. Asus Vivobook Q301LA-BHI5T02 Motherboard Replacement: étape 20, image 1 de 1
    • Disconnect the motherboard from the connector shown.
  21. Asus Vivobook Q301LA-BHI5T02 Motherboard Replacement: étape 21, image 1 de 1
    • Pull the motherboard loose.
  22. Asus Vivobook Q301LA-BHI5T02 Motherboard Replacement: étape 22, image 1 de 1
    • Disconnect the motherboard from the connector shown and it is now removed from your device.
Caleb Ellis
Membre depuis le 11/06/18
133 Réputation
1 tutoriel rédigé
Équipe
UMass Dartmouth, Team S5-G3, Gulbrandsen Fall 2018 Membre de l'équipe UMass Dartmouth, Team S5-G3, Gulbrandsen Fall 2018
UMASSD-GULBRANDSEN-F18S5G3
3 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 11
Total : 480
