Aller au contenu principal
Asus X200CA Display Replacement
Ce dont vous avez besoin
  1. Asus X200CA Display Replacement, Display: étape 1, image 1 de 1
    • Wedge a metal spudger between the bezel and display cover.
    • Slide the metal spudger back and forth along the top, left, and right sides to pry apart the screen from the outer shell.
  2. Asus X200CA Display Replacement: étape 2, image 1 de 2 Asus X200CA Display Replacement: étape 2, image 2 de 2
    • Remove the six silver 2.7 mm screws securing the screen bracket to the screen bezel.
  3. Asus X200CA Display Replacement: étape 3, image 1 de 2 Asus X200CA Display Replacement: étape 3, image 2 de 2
    • Slice the silver foil tape with a spudger by applying pressure between the frame and the back of the screen case.
  4. Asus X200CA Display Replacement: étape 4, image 1 de 1
    • Pull apart the black fabric tape with your fingers.
  5. Asus X200CA Display Replacement: étape 5, image 1 de 2 Asus X200CA Display Replacement: étape 5, image 2 de 2
    • Use an opening tool to peel off the sticker label securing the LCD cable to the LCD display.
    • Gently pull the sticker to disconnect the LCD cable.
    • Potential for device damage: Do not use excessive force while removing the video cable attached to the back of the LCD.
  6. Asus X200CA Display Replacement: étape 6, image 1 de 1
    • Lift the LCD screen to remove it from the device.
  7. Asus X200CA Display Replacement: étape 7, image 1 de 3 Asus X200CA Display Replacement: étape 7, image 2 de 3 Asus X200CA Display Replacement: étape 7, image 3 de 3
    • Remove the four silver 2.7 mm screws to separate the LCD screen from the two screen brackets.
3 autres ont terminé cette réparation.
Jacqueline Collier
Membre depuis le 10/09/17
1 047 Réputation
5 tutoriels rédigés
Équipe
USF Tampa, Team S1-G2, Leahy Fall 2017 Membre de l'équipe USF Tampa, Team S1-G2, Leahy Fall 2017
USFT-LEAHY-F17S1G2
4 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 2
30 derniers jours : 26
Total : 1,797
