Ce dont vous avez besoin
Étape 1 Removing the back cover
Attention : les étapes 1 à 3 sont issues d'un tutoriel marqué comme étant en cours.
With the back camera on the top side and facing you, find a notch on the bottom right side of the phone.
Unclip the cover by raising it up from the notch and sliding a flat rigid tool along the edge.
Remove the battery.
Remove 3 screws from each side with a Phillips 00 screwdriver.
Unclip the screen by sliding a flat rigid tool between the black and the blue side-band.
Pop off the blue side-band to be exposed to the motherboard.
Remove 2 black plastic buttons from each side, exposing metallic padding.
Gently pry the metallic padding off the motherboard with a flat rigid tool.
Carefully separate the clip-on tabs while lifting the motherboard away from the screen.
Once phone is completely disassmbled, you will take your soldering iron to the charger port to remove it.
4 autres ont terminé cette réparation.
