Aller au contenu principal
Barrel Reloading Mechanishm
Ce dont vous avez besoin
  1. Barrel Reloading Mechanishm, Barrel Reloading Mechanism: étape 1, image 1 de 2 Barrel Reloading Mechanishm, Barrel Reloading Mechanism: étape 1, image 2 de 2
    • Unscrew all of the 12 screws on the Nerf gun.
  2. Barrel Reloading Mechanishm: étape 2, image 1 de 1
    • Remember to remove the grey part of the reloader that is not attached to the gun.
  3. Barrel Reloading Mechanishm: étape 3, image 1 de 2 Barrel Reloading Mechanishm: étape 3, image 2 de 2
    • Remove top outer shell.
    • Remove orange attachment tab.
  4. Barrel Reloading Mechanishm: étape 4, image 1 de 2 Barrel Reloading Mechanishm: étape 4, image 2 de 2
    • Remove the screw that holds the trigger in place.
  5. Barrel Reloading Mechanishm: étape 5, image 1 de 2 Barrel Reloading Mechanishm: étape 5, image 2 de 2
    • Remove the reloader trigger that is triggered by the trigger. Lol I just had to say that.
    • Putting this piece back in the gun can be frustrating since it is spring loaded. Here's a tip. Put the orange trigger(the piece in the red circle) on first, than slip the spring through the opening on the piece.
  6. Barrel Reloading Mechanishm: étape 6, image 1 de 2 Barrel Reloading Mechanishm: étape 6, image 2 de 2
    • Remove the barrel that holds the Nerf darts.
    • Be careful on removing the barrel since it could do more harm to your already damaged barrel reloader.
  7. Barrel Reloading Mechanishm: étape 7, image 1 de 2 Barrel Reloading Mechanishm: étape 7, image 2 de 2
    • Remove the air piston and barrel turning part. This is the part you will be working on.
  8. Barrel Reloading Mechanishm: étape 8, image 1 de 1
    • Move the other parts of the Nerf gun away from the air piston and barrel rotator part.
  9. Barrel Reloading Mechanishm: étape 9, image 1 de 2 Barrel Reloading Mechanishm: étape 9, image 2 de 2
    • Remove screws from the piece that is holding the barrel reloading piston in place.
  10. Barrel Reloading Mechanishm: étape 10, image 1 de 1
    • Remove the piece holding the barrel reloading piston.
  11. Barrel Reloading Mechanishm: étape 11, image 1 de 1
    • If your piston looks like this in the picture, you will need to either find a screw that is less than or equal to the size of one of the screws on your weapon.
  12. Barrel Reloading Mechanishm: étape 12, image 1 de 3 Barrel Reloading Mechanishm: étape 12, image 2 de 3 Barrel Reloading Mechanishm: étape 12, image 3 de 3
    • Once you have found a screw, use a hot glue gun or super glue and layer it around the screw to keep it from wobbling.
  13. Barrel Reloading Mechanishm: étape 13, image 1 de 1
    • It is a good idea to test the barrel reloading mechanism by pulling the barrel reloading piston back and forth. If the orange circle that attaches to the dart barrel spins then that is a good sign.
    • If it is not working, try pulling the screw out and screw (or push) it back in the other way.
  14. Barrel Reloading Mechanishm: étape 14, image 1 de 1
    • This is what your array of parts should look like.
    • Make sure you do NOT loose the spring circled in red in the picture. If you do then your weapon will have to be a manual reloading gun.
  15. Barrel Reloading Mechanishm: étape 15, image 1 de 1
    • The rough white cylinder circled in red on this picture will be covered in some grease. Do NOT wash it off.
  16. Barrel Reloading Mechanishm: étape 16, image 1 de 2 Barrel Reloading Mechanishm: étape 16, image 2 de 2
    • Now put the piston back in place.
  17. Barrel Reloading Mechanishm: étape 17, image 1 de 3 Barrel Reloading Mechanishm: étape 17, image 2 de 3 Barrel Reloading Mechanishm: étape 17, image 3 de 3
    Outil utilisé dans cette étape :
    • Now grab your tweezers and place the spring back in place by attaching it on the two white poles circled in red. This is something you should do if your spring fell off.
  18. Barrel Reloading Mechanishm, Tips:: étape 18, image 1 de 3 Barrel Reloading Mechanishm, Tips:: étape 18, image 2 de 3 Barrel Reloading Mechanishm, Tips:: étape 18, image 3 de 3
    • Tips:
    • If any of the springs fall off inside the weapon or the weapon's parts you can use the tweezers to grab them.
    • If your Nerf Elite Strongarm is still not working here is a link to a Reddit post posted by someone who had a similiar problem.Strongarm barrel doesn't rotate
    • Sometimes during use the barrel will need to be turned(but make sure you do not push it beyond its limits) or you can just jerk the gun to the side.
4 autres ont terminé cette réparation.
[deleted]
Membre depuis le 03/09/17
405 Réputation
2 tutoriels rédigés
4 commentaires
Excellent guide, thanks for putting it together! We got a brand new Strongarm we couldn’t return so I followed your guide to take it apart. However, nothing was broken.
We noticed the barrel rotated fine when manually pulling the mechanism when the blaster was apart, but it wasn’t rotating when screwed back together. I applied some Super Lube grease to several areas in the mechanism where I thought friction might be introduced and, voila! The blaster fires and slam fires reliably.
Without your guide I would’ve been really stuck, though. Thank you!
Jeremiah - Réponse
You’re welcome!
[deleted] -
Thank you! I realized after this that one of my springs was out of place, and so the blaster was not working properly. Thank you for the help!
Cameron Minnes - Réponse
No problem! Happy to help! :)
[deleted] -
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 4
7 derniers jours : 14
30 derniers jours : 47
Total : 8,881
