Aller au contenu principal
Beats Studio 2 Wireless Battery Replacement
Ce dont vous avez besoin
  1. Beats Studio 2 Wireless Battery Replacement, Battery: étape 1, image 1 de 2 Beats Studio 2 Wireless Battery Replacement, Battery: étape 1, image 2 de 2
    • Using a spudger, remove the panel circling the ‘b’ Beats logo on the right earphone by applying pressure upwards under the panel until it is removed.
  2. Beats Studio 2 Wireless Battery Replacement: étape 2, image 1 de 2 Beats Studio 2 Wireless Battery Replacement: étape 2, image 2 de 2
    • Remove the four screws securing the housing with a Phillips #00 screwdriver.
  3. Beats Studio 2 Wireless Battery Replacement: étape 3, image 1 de 1
    • Use a spudger to release the clip in the seam under the silver “studio” label.
    • Remove the right side of the headband.
  4. Beats Studio 2 Wireless Battery Replacement: étape 4, image 1 de 1
    • Gently remove the right earphone speaker from the headband by sliding the speaker downwards.
  5. Beats Studio 2 Wireless Battery Replacement: étape 5, image 1 de 3 Beats Studio 2 Wireless Battery Replacement: étape 5, image 2 de 3 Beats Studio 2 Wireless Battery Replacement: étape 5, image 3 de 3
    • Use the pointed tip of a spudger to carefully push on each side of the connector to release it from the socket on the motherboard.
    • Be gentle with the connectors as they can break easily.
    • Don't use a metal spudger to remove a battery or any internal component. This is potentially dangerous as it could puncture the battery and cause a fire or worse.
    • Use a nylon spudger to remove the battery from the headphones.
2 autres ont terminé cette réparation.
Jack Wilson
Membre depuis le 03/20/23
494 Réputation
2 tutoriels rédigés
Équipe
UMass Dartmouth, Team 5-3, Ramos Spring 2023 Membre de l'équipe UMass Dartmouth, Team 5-3, Ramos Spring 2023
UMASSD-RAMOS-S23S5G3
3 membres
4 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 5
7 derniers jours : 53
30 derniers jours : 174
Total : 2,019
