Aller au contenu principal
Behringer BCD3000 Disassembly
Ce dont vous avez besoin
  1. Behringer BCD3000 Disassembly, Behringer BCD3000 Disassembly: étape 1, image 1 de 1
    • Unplug from all cables
  2. Behringer BCD3000 Disassembly, opening the sides: étape 2, image 1 de 2 Behringer BCD3000 Disassembly, opening the sides: étape 2, image 2 de 2
    • unscrew two Phillips screws on each side of the BCD3000
    • If the screws sit too tight, you can use the extension for better torque
  3. Behringer BCD3000 Disassembly, loosening the top part: étape 3, image 1 de 2 Behringer BCD3000 Disassembly, loosening the top part: étape 3, image 2 de 2
    • unscrew another two Phillips screws on each side
  4. Behringer BCD3000 Disassembly: étape 4, image 1 de 3 Behringer BCD3000 Disassembly: étape 4, image 2 de 3 Behringer BCD3000 Disassembly: étape 4, image 3 de 3
    • Lift the upper control part.
    • Be careful, there are still some cables connected to the lower section.
    • Disconnect the cables by walking them out of their sockets.
  5. Behringer BCD3000 Disassembly: étape 5, image 1 de 1
    • Remove the upper part completely.
  6. Behringer BCD3000 Disassembly: étape 6, image 1 de 1
    • Disconnect the two cables from the lower section to the connector board.
  7. Behringer BCD3000 Disassembly: étape 7, image 1 de 3 Behringer BCD3000 Disassembly: étape 7, image 2 de 3 Behringer BCD3000 Disassembly: étape 7, image 3 de 3
    • Slide the lower section to the front.
    • Now you can lift it and take it aside.
  8. Behringer BCD3000 Disassembly: étape 8, image 1 de 3 Behringer BCD3000 Disassembly: étape 8, image 2 de 3 Behringer BCD3000 Disassembly: étape 8, image 3 de 3
    • Disconnect the separate boards.
    • Now you can take the modules out by unscrewing them from the case.
  9. Behringer BCD3000 Disassembly: étape 9, image 1 de 2 Behringer BCD3000 Disassembly: étape 9, image 2 de 2
    • The jog wheels on the front panel can be taken off by using a spudger and levering them out.
  10. Behringer BCD3000 Disassembly: étape 10, image 1 de 2 Behringer BCD3000 Disassembly: étape 10, image 2 de 2
    • The knobs can easy be removed just by pulling.
  11. Behringer BCD3000 Disassembly: étape 11, image 1 de 3 Behringer BCD3000 Disassembly: étape 11, image 2 de 3 Behringer BCD3000 Disassembly: étape 11, image 3 de 3
    • Same goes for the knobs on the top section of the front panel.
4 autres ont terminé cette réparation.
Tobias Isakeit
Membre depuis le 03/31/14
107 178 Réputation
185 tutoriels rédigés
Équipe
iFixit Membre de l'équipe iFixit
Community
139 membres
16 884 tutoriels rédigés
2 commentaires
Pensaba que serviría para la BCD2000… pero es algo distinta.
Antonio - Réponse
great stuff, with better quality pictures would be better
csipapicsa - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 9
30 derniers jours : 35
Total : 2,061
