Aller au contenu principal
Bissell Air180 Motherboard Replacement
Ce dont vous avez besoin
  1. Bissell Air180 Motherboard Replacement, Air Filter: étape 1, image 1 de 2 Bissell Air180 Motherboard Replacement, Air Filter: étape 1, image 2 de 2
    • Squeeze the clip on the back panel of the bottom housing and pull the panel away from the housing, exposing the air filter.
  2. Bissell Air180 Motherboard Replacement: étape 2, image 1 de 1
    • Grab the sides of the filter and pull it up.
  3. Bissell Air180 Motherboard Replacement: étape 3, image 1 de 1
    • Pull the filter away from the bottom housing, removing it from the rest of the device.
  4. Bissell Air180 Motherboard Replacement, Power Supply: étape 4, image 1 de 1
    • Remove the four 18mm Phillips #1 screws connecting the bottom housing to the rest of the device.
  5. Bissell Air180 Motherboard Replacement: étape 5, image 1 de 3 Bissell Air180 Motherboard Replacement: étape 5, image 2 de 3 Bissell Air180 Motherboard Replacement: étape 5, image 3 de 3
    • Pull the bottom housing away from the rest of the device separating the power supply.
    • Unplug the red cord to fully disconnect the power supply from the fan and motherboard housing.
  6. Bissell Air180 Motherboard Replacement, Control Buttons: étape 6, image 1 de 3 Bissell Air180 Motherboard Replacement, Control Buttons: étape 6, image 2 de 3 Bissell Air180 Motherboard Replacement, Control Buttons: étape 6, image 3 de 3
    • Pry off the top vent, separating it from the fan and motherboard housing.
  7. Bissell Air180 Motherboard Replacement: étape 7, image 1 de 2 Bissell Air180 Motherboard Replacement: étape 7, image 2 de 2
    • Pry the button control panel up and away from the rest of the device using a spudger.
  8. Bissell Air180 Motherboard Replacement: étape 8, image 1 de 2 Bissell Air180 Motherboard Replacement: étape 8, image 2 de 2
    • Pull the wire connecting the button controls to the fan housing to fully disconnect the button controls from the device.
  9. Bissell Air180 Motherboard Replacement, Fan: étape 9, image 1 de 3 Bissell Air180 Motherboard Replacement, Fan: étape 9, image 2 de 3 Bissell Air180 Motherboard Replacement, Fan: étape 9, image 3 de 3
    • Flip the motherboard and fan housing upside down to find where to disconnect the fan from the rest of the device.
    • Remove the two 11 mm screws using a Phillips #1 screwdriver.
    • Detach the two wires connecting the fan to the motherboard so the fan is now loose inside the housing.
  10. Bissell Air180 Motherboard Replacement: étape 10, image 1 de 2 Bissell Air180 Motherboard Replacement: étape 10, image 2 de 2
    • Flip the motherboard and fan housing back over and pull the fan up separating it from the rest of the device.
  11. Bissell Air180 Motherboard Replacement, Motherboard: étape 11, image 1 de 2 Bissell Air180 Motherboard Replacement, Motherboard: étape 11, image 2 de 2
    • Apply pressure and push out the control knob to remove the motherboard from the rest of the device.
    • Removing the two 11mm Phillips #1 screws when disconnecting the fan also disconnected the motherboard from the rest of the device.
Aleah Ramos
Membre depuis le 10/26/22
533 Réputation
5 tutoriels rédigés
Équipe
UMass Dartmouth, Team 3-4, Botvin Fall 2022 Membre de l'équipe UMass Dartmouth, Team 3-4, Botvin Fall 2022
UMASSD-BOTVIN-F22S3G4
4 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 2
Total : 119
