Aller au contenu principal
Bissell CrossWave Cordless Max 2554A Handle Replacement
Ce dont vous avez besoin
  1. Bissell CrossWave Cordless Max 2554A Handle Replacement, Handle: étape 1, image 1 de 1
    • Start by facing the vacuum away from you so that you are looking at the back side of the clean water tank.
  2. Bissell CrossWave Cordless Max 2554A Handle Replacement: étape 2, image 1 de 3 Bissell CrossWave Cordless Max 2554A Handle Replacement: étape 2, image 2 de 3 Bissell CrossWave Cordless Max 2554A Handle Replacement: étape 2, image 3 de 3
    • The handle release mechanism is a small hole directly above the clean water tank and below the handle.
    • Using the pointed end of a spudger, press the mechanism to release the handle.
    • You might need to shimmy it a bit, as pressing too hard may prevent the handle from releasing.
  3. Bissell CrossWave Cordless Max 2554A Handle Replacement: étape 3, image 1 de 2 Bissell CrossWave Cordless Max 2554A Handle Replacement: étape 3, image 2 de 2
    • Remove the handle from the vacuum.
To reassemble your device, reinsert the handle back into the main body of the vacuum, listening for an audible click.
Craig Bowlin
Membre depuis le 02/15/24
898 Réputation
7 tutoriels rédigés
Équipe
University of Memphis, Team 4-2, Sneed Spring 2024 Membre de l'équipe University of Memphis, Team 4-2, Sneed Spring 2024
UM-SNEED-S24S4G2
4 membres
9 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 9
30 derniers jours : 28
Total : 196
