Aller au contenu principal
Black and Decker DCM100R Heating Element Replacement
Ce dont vous avez besoin
  1. Black and Decker DCM100R Heating Element Replacement, Heating Element: étape 1, image 1 de 2 Black and Decker DCM100R Heating Element Replacement, Heating Element: étape 1, image 2 de 2
    • Turn the coffee maker on its side.
    • Remove the four 6 mm Phillips #2 that secure the baseplate.
  2. Black and Decker DCM100R Heating Element Replacement: étape 2, image 1 de 3 Black and Decker DCM100R Heating Element Replacement: étape 2, image 2 de 3 Black and Decker DCM100R Heating Element Replacement: étape 2, image 3 de 3
    • Insert the jimmy at the back of the panel and slide it around to the front.
  3. Black and Decker DCM100R Heating Element Replacement: étape 3, image 1 de 3 Black and Decker DCM100R Heating Element Replacement: étape 3, image 2 de 3 Black and Decker DCM100R Heating Element Replacement: étape 3, image 3 de 3
    • Apply pressure to the backside of the panel until it releases.
    • Remove the plate.
  4. Black and Decker DCM100R Heating Element Replacement: étape 4, image 1 de 2 Black and Decker DCM100R Heating Element Replacement: étape 4, image 2 de 2
    • Remove the two 10 mm Phillips #2 screws securing the metal support brace.
    • Remove the brace and set aside.
  5. Black and Decker DCM100R Heating Element Replacement: étape 5, image 1 de 2 Black and Decker DCM100R Heating Element Replacement: étape 5, image 2 de 2
    Outil utilisé dans cette étape :
    J'achète
    • Pull back the tubing and wiring to reveal the hot plate.
    • To hold these out of your way, you can use the Nylon Tipped Tweezers to pin them back to the back panel.
  6. Black and Decker DCM100R Heating Element Replacement: étape 6, image 1 de 2 Black and Decker DCM100R Heating Element Replacement: étape 6, image 2 de 2
    • Use a Phillips #2 screwdriver to remove the five 8 mm screws that secure the mounting bracket and hot plate.
  7. Black and Decker DCM100R Heating Element Replacement: étape 7, image 1 de 2 Black and Decker DCM100R Heating Element Replacement: étape 7, image 2 de 2
    • Use a pair of pliers to gently pull the mounting bracket out of place.
  8. Black and Decker DCM100R Heating Element Replacement: étape 8, image 1 de 3 Black and Decker DCM100R Heating Element Replacement: étape 8, image 2 de 3 Black and Decker DCM100R Heating Element Replacement: étape 8, image 3 de 3
    • Remove the hot plate from the mounting bracket.
    • Remove the O-ring from the hot plate.
Ella Barbour
Membre depuis le 09/13/23
207 Réputation
1 tutoriel rédigé
Équipe
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 3
30 derniers jours : 13
Total : 155
