Aller au contenu principal
Black and Decker JE2200B Motor Compartment Replacement
Ce dont vous avez besoin
  1. Black and Decker JE2200B Motor Compartment Replacement, Motor Compartment: étape 1, image 1 de 1
  2. Black and Decker JE2200B Motor Compartment Replacement: étape 2, image 1 de 2 Black and Decker JE2200B Motor Compartment Replacement: étape 2, image 2 de 2
    Outil utilisé dans cette étape :
    Flathead 3/32" or 2.5 mm Screwdriver
    $5.49
    J'achète
    • Use the 2.5 mm Flathead adapter to remove the 13.5 mm screws from the bottom of the juicer. The screw head diameter is 5.2 mm.
  3. Black and Decker JE2200B Motor Compartment Replacement: étape 3, image 1 de 2 Black and Decker JE2200B Motor Compartment Replacement: étape 3, image 2 de 2
    • Carefully remove the bottom off the rest of the machine.
  4. Black and Decker JE2200B Motor Compartment Replacement: étape 4, image 1 de 1
    • Lay the juicer horizontally and roll the top shaft cover until it comes off.
  5. Black and Decker JE2200B Motor Compartment Replacement: étape 5, image 1 de 1
    • Unscrew the 19.1 mm screws inside the juicer holding the motor compartment attached to the juicer. Use the 2.5 mm Flathead adapter as the screw driver. The diameter of the screw head is 7.1 mm.
  6. Black and Decker JE2200B Motor Compartment Replacement: étape 6, image 1 de 3 Black and Decker JE2200B Motor Compartment Replacement: étape 6, image 2 de 3 Black and Decker JE2200B Motor Compartment Replacement: étape 6, image 3 de 3
    • Remove the motor compartment from the juicer and it is ready to be replaced.
4 autres ont terminé cette réparation.
Bhavika Shah
Membre depuis le 08/27/15
331 Réputation
2 tutoriels rédigés
Équipe
USF Tampa, Team 5-5, Blackwell Fall 2015 Membre de l'équipe USF Tampa, Team 5-5, Blackwell Fall 2015
USFT-BLACKWELL-F15S5G5
3 membres
6 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 10
30 derniers jours : 35
Total : 1,281
