Aller au contenu principal
Black and Decker Toast R Oven Knobs Replacement
Ce dont vous avez besoin
  1. Black and Decker Toast R Oven Knobs Replacement, Knobs: étape 1, image 1 de 1
    • Make sure that the toaster is unplugged before you begin.
    • Turn the toaster upside down and remove the two Phillips #4 1 cm screws attached to the side panels.
  2. Black and Decker Toast R Oven Knobs Replacement: étape 2, image 1 de 2 Black and Decker Toast R Oven Knobs Replacement: étape 2, image 2 de 2
    • Pull down and out to remove side panels from the unit
    • Repeat for the other side.
  3. Black and Decker Toast R Oven Knobs Replacement: étape 3, image 1 de 1
    • Remove the bottom vent.
    • This should come off fairly easy.
  4. Black and Decker Toast R Oven Knobs Replacement: étape 4, image 1 de 1
    • Remove the two Phillips #4 1 cm screws that connect the bottom panel to the unit.
  5. Black and Decker Toast R Oven Knobs Replacement: étape 5, image 1 de 1
    • Remove the crumb tray (bottom metal panel) from the toaster unit.
  6. Black and Decker Toast R Oven Knobs Replacement: étape 6, image 1 de 1
    • Remove the aluminum strip on the bottom of the unit.
  7. Black and Decker Toast R Oven Knobs Replacement: étape 7, image 1 de 1
    • Remove knobs by pulling up on them.
  8. Black and Decker Toast R Oven Knobs Replacement: étape 8, image 1 de 1
    • Unhook the bottom of the display panel from the toaster unit.
    • It will be a little tough to pry off, but don't be afraid to be forceful.
  9. Black and Decker Toast R Oven Knobs Replacement: étape 9, image 1 de 1
    • Begin to detach the back panel from the toaster unit and unhook the rest of the display panel.
    • This will also be a little tough to get off, but don't be afraid to be forceful.
To reassemble your toaster, follow these directions in reverse.
Jonathan
Membre depuis le 09/18/12
320 Réputation
5 tutoriels rédigés
Équipe
Cal Poly, Team 2-10, Propen Fall 2012 Membre de l'équipe Cal Poly, Team 2-10, Propen Fall 2012
CPSU-PROPEN-F12S2G10
4 membres
5 tutoriels rédigés
Un commentaire
very interesting post
James Evans - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 21
30 derniers jours : 47
Total : 5,150
