Aller au contenu principal
Black and Decker Toast R Oven Knobs Replacement
Jonathan
Jonathan et 7 autres contributeurs
Dernière mise à jour le February 5, 2021
Aucune estimation
Modérée
Before replacing knobs you will have to disassemble oven to take off the knobs and faceplate.
Ce dont vous avez besoin
iFixit touche une commission lorsque vous achetez par l'intermédiaire de ces liens.
  1. Black and Decker Toast R Oven Knobs Replacement, Knobs: étape 1, image 1 de 1
    • Make sure that the toaster is unplugged before you begin.
    • Turn the toaster upside down and remove the two Phillips #4 1 cm screws attached to the side panels.
  2. Black and Decker Toast R Oven Knobs Replacement: étape 2, image 1 de 2 Black and Decker Toast R Oven Knobs Replacement: étape 2, image 2 de 2
    • Pull down and out to remove side panels from the unit
    • Repeat for the other side.
  3. Black and Decker Toast R Oven Knobs Replacement: étape 3, image 1 de 1
    • Remove the bottom vent.
    • This should come off fairly easy.
  4. Black and Decker Toast R Oven Knobs Replacement: étape 4, image 1 de 1
    • Remove the two Phillips #4 1 cm screws that connect the bottom panel to the unit.
  5. Black and Decker Toast R Oven Knobs Replacement: étape 5, image 1 de 1
    • Remove the crumb tray (bottom metal panel) from the toaster unit.
  6. Black and Decker Toast R Oven Knobs Replacement: étape 6, image 1 de 1
    • Remove the aluminum strip on the bottom of the unit.
  7. Black and Decker Toast R Oven Knobs Replacement: étape 7, image 1 de 1
    • Remove knobs by pulling up on them.
  8. Black and Decker Toast R Oven Knobs Replacement: étape 8, image 1 de 1
    • Unhook the bottom of the display panel from the toaster unit.
    • It will be a little tough to pry off, but don't be afraid to be forceful.
  9. Black and Decker Toast R Oven Knobs Replacement: étape 9, image 1 de 1
    • Begin to detach the back panel from the toaster unit and unhook the rest of the display panel.
    • This will also be a little tough to get off, but don't be afraid to be forceful.
To reassemble your toaster, follow these directions in reverse.
Jonathan
Membre depuis le 09/18/12
320 Réputation
5 tutoriels rédigés
Équipe
Cal Poly, Team 2-10, Propen Fall 2012 Membre de l'équipe Cal Poly, Team 2-10, Propen Fall 2012
CPSU-PROPEN-F12S2G10
4 membres
5 tutoriels rédigés
1 commentaire de tutoriel
very interesting post
James Evans - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 9
30 derniers jours : 26
Total : 5,183
