Introduction
If your screen is cracked or damaged, then you will need to replace your screen. Use these step-by-step instructions to replace your BlackBerry Tour 9630 LCD screen.
Ce dont vous avez besoin
If there is an SD card, press gently on the card and slide up to remove.
If there is a SIM card, press gently on the card and slide left to remove.
Use the T6 Torx screwdriver to remove the four 8.00mm screws from the back of the phone.
Gently lift the motherboard to expose several ribbon cables.
Use the small plastic opening tool to disconnect the orange LCD ribbon from the square end of the ribbon cables.
3 autres ont terminé cette réparation.
