Aller au contenu principal
Blackberry Curve 8320 Front Panel Replacement
Ce dont vous avez besoin
  1. Blackberry Curve 8320 Front Panel Replacement, Battery: étape 1, image 1 de 2 Blackberry Curve 8320 Front Panel Replacement, Battery: étape 1, image 2 de 2
    • Hold the phone with the back facing you.
    • Press the silver tab down and remove the cover.
  2. Blackberry Curve 8320 Front Panel Replacement: étape 2, image 1 de 1
    • Pull up on the top edge of the battery to remove it.
  3. Blackberry Curve 8320 Front Panel Replacement, Front Panel: étape 3, image 1 de 3 Blackberry Curve 8320 Front Panel Replacement, Front Panel: étape 3, image 2 de 3 Blackberry Curve 8320 Front Panel Replacement, Front Panel: étape 3, image 3 de 3
    • Use a plastic opening tool to gently pry the bottom cover loose.
    • Do not use excessive force at risk of damaging the antenna, which is under this casing.
    • Pull the cover from the front of the phone after the back is loose.
  4. Blackberry Curve 8320 Front Panel Replacement: étape 4, image 1 de 2 Blackberry Curve 8320 Front Panel Replacement: étape 4, image 2 de 2
    • Remove the two top screws with a T5 Torx screwdriver.
    • The screws are 8mm long.
  5. Blackberry Curve 8320 Front Panel Replacement: étape 5, image 1 de 2 Blackberry Curve 8320 Front Panel Replacement: étape 5, image 2 de 2
    • Gently pry off the side casings from the top.
    • The side casings cannot be fully removed yet because they are screwed on at the bottom.
    • You will not need to remove the sides on the bottom.
  6. Blackberry Curve 8320 Front Panel Replacement: étape 6, image 1 de 1
    • Use a plastic opening tool to detach the securing clips holding the the front panel in place.
    • There are six securing clips total.
  7. Blackberry Curve 8320 Front Panel Replacement: étape 7, image 1 de 1
    • Carefully remove the front panel.
    • You may need to apply some force in removing because the front panel is attached to the rest of the device with adhesive.
Christopher Aiello
Membre depuis le 10/12/11
89 Réputation
5 tutoriels rédigés
Équipe
Cal Poly, Team 3-6, Regan Fall 2011 Membre de l'équipe Cal Poly, Team 3-6, Regan Fall 2011
CPSU-REGAN-F11S3G6
5 membres
9 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 15
Total : 2,696
