Aller au contenu principal
Blu Grand M Display Replacement
Ce dont vous avez besoin
  1. Blu Grand M Display Replacement, Display: étape 1, image 1 de 1
    • Trace the outer black edge of the phone screen in a continuous circle with a hairdryer or heat gun to melt the adhesive.
    • Melting the adhesive can take between 2-3 minutes.
  2. Blu Grand M Display Replacement: étape 2, image 1 de 3 Blu Grand M Display Replacement: étape 2, image 2 de 3 Blu Grand M Display Replacement: étape 2, image 3 de 3
    Outil utilisé dans cette étape :
    Halberd Spudger
    $2.99
    • Insert an opening pick between the screen and the raised black plastic frame.
    • The black plastic frame is located inside and above the phone's silvery outer metal frame.
    • Insert the flat blade of a nylon halberd spudger between the screen and the black plastic frame.
    • Pull the spudger blade through the adhesive around the circumference of the screen.
  3. Blu Grand M Display Replacement: étape 3, image 1 de 3 Blu Grand M Display Replacement: étape 3, image 2 de 3 Blu Grand M Display Replacement: étape 3, image 3 de 3
    • Apply the suction cup to the phone screen, pressing lightly on the suction cup to remove air and form a tight seal.
    • The adhesive may have cooled from the time since step 1 and rebonded to the phone screen. Reheat the adhesive if necessary to return to a liquid state.
    • Pull on the handle to lift the screen free from the device.
Ligne d'arrivée
Liam Rollins
Membre depuis le 11/04/19
253 Réputation
2 tutoriels rédigés
Équipe
0Commentaires sur le guide
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 2
30 derniers jours : 2
Total : 269
