Introduction
Use this guide to learn how to replace your left and right speaker drivers for the Bowers and Wilkins T7 Bluetooth Speaker.
Ce dont vous avez besoin
Remove 14mm screws on the front panel with a J1 Phillips head screwdriver.
There are 8 screws in total.
FYI: I bought the Ifixit toolkit and sadly the screw driver isn’t long enough to remove the 4 middle screws.
What sizes are the screws exactly? I took mine apart and someone threw out the screws so now I need replacements.
Using the ifixit Opening Tool, pry open at the seam found under the rubber seal.
As the cover starts to come off, you can lift up using your hand.
I used a sharp knife. Note carefully where the seam is in the above diagram: on the back about 7 mm from the edge.
Outil utilisé dans cette étape :Tweezers$4.99
Gently squeeze the internal locking mechanism inside the red and white terminals with either your fingers or a pair of precision tweezers.
While squeezing the internal locking mechanism, pull back the terminal.
Repeat this process for the second speaker.
Remove the 7mm screws around the speaker using a J100 Phillips head screwdriver.
There are 4 screws in total around each speaker.
2 autres ont terminé cette réparation.
2 commentaires
Where do you buy the replacement driver?
Tôi có cùng một câu hỏi? Tôi sẽ phải mua chúng ở đâu.
My model does not have screws in the front as indicates here. Not sure what to do now
thebolts - Réponse
