Aller au contenu principal
Briggs and Stratton 675 Series Spark Plug Replacement
Ce dont vous avez besoin
  1. Briggs and Stratton 675 Series Spark Plug Replacement, Cap Removal: étape 1, image 1 de 2 Briggs and Stratton 675 Series Spark Plug Replacement, Cap Removal: étape 1, image 2 de 2
    • Make sure the engine is turned off before beginning.
    • Use your hands to remove the spark plug wire. It should pop off easily with little effort
  2. Briggs and Stratton 675 Series Spark Plug Replacement, Spark Plug Removal: étape 2, image 1 de 3 Briggs and Stratton 675 Series Spark Plug Replacement, Spark Plug Removal: étape 2, image 2 de 3 Briggs and Stratton 675 Series Spark Plug Replacement, Spark Plug Removal: étape 2, image 3 de 3
    • Use a socket wrench with a 13/16" hex bit to unscrew the spark plug from the engine. You will probably need to use a long hex bit in order to get to the bolt.
    • Pull the spark plug out of its housing with your hands.
    • Alternatively, you may use a wrench or pliers to remove the spark plug instead. (Shown in the second image.)
7 autres ont terminé cette réparation.
Andrew Saunders
Membre depuis le 02/01/15
981 Réputation
2 tutoriels rédigés
Équipe
Cal Poly, Team 6-31, Amido Winter 2015 Membre de l'équipe Cal Poly, Team 6-31, Amido Winter 2015
CPSU-AMIDO-W15S6G31
4 membres
18 tutoriels rédigés
13 commentaires
I have a Briggs and Stratton engine on my lawn mower but can't get at the spark plug as there is some kind of black plastic housing in front of it.
penora - Réponse
Any ideas I have a Briggs and Stratton engine on my lawn mower but can't get at the spark plug as there is some kind of black plastic housing in front of it.
penora - Réponse
pinch the front of black cap and pull off
tracy.mullen - Réponse
What size spark plug does this 675 series lawn mower take, I didn't see it listed?
Eris - Réponse
Kymberleah - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 7
7 derniers jours : 47
30 derniers jours : 183
Total : 49,516
