Aller au contenu principal
CHI Spin N Curl Rotating Curler Temperature Control Switch Replacement
Ce dont vous avez besoin
  1. CHI Spin N Curl Rotating Curler Temperature Control Switch Replacement, Power Cord: étape 1, image 1 de 1
    • Use a metal spudger to pry off the silver, shiny trim.
  2. CHI Spin N Curl Rotating Curler Temperature Control Switch Replacement: étape 2, image 1 de 1
    • Remove inner black housing of the CHI Spin N Curl using the metal spudger to pop it out.
  3. CHI Spin N Curl Rotating Curler Temperature Control Switch Replacement: étape 3, image 1 de 2 CHI Spin N Curl Rotating Curler Temperature Control Switch Replacement: étape 3, image 2 de 2
    • Use a 2 mm flathead to remove the two screws.
  4. CHI Spin N Curl Rotating Curler Temperature Control Switch Replacement: étape 4, image 1 de 2 CHI Spin N Curl Rotating Curler Temperature Control Switch Replacement: étape 4, image 2 de 2
    • Use a metal spudger to pry open the seams of the device.
  5. CHI Spin N Curl Rotating Curler Temperature Control Switch Replacement: étape 5, image 1 de 3 CHI Spin N Curl Rotating Curler Temperature Control Switch Replacement: étape 5, image 2 de 3 CHI Spin N Curl Rotating Curler Temperature Control Switch Replacement: étape 5, image 3 de 3
    • Toward the bottom of the device, grab the swivel power cord.
    • Gently pull the power cord to detach it from the CHI Spin N Curl
    • Replace the faulty cord when the original cord has been removed.
  6. CHI Spin N Curl Rotating Curler Temperature Control Switch Replacement, Temperature Control Switch: étape 6, image 1 de 1
    • Use a Phillips #00 screwdriver to remove the screws on both sides of the temperature control switch.
    • Pop out the control switch.
Annalise White
Membre depuis le 10/26/22
530 Réputation
5 tutoriels rédigés
Équipe
UMass Dartmouth, Team 2-7, Petersen Fall 2022 Membre de l'équipe UMass Dartmouth, Team 2-7, Petersen Fall 2022
UMASSD-PETERSEN-F22S2G7
3 membres
6 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 8
Total : 221
