Introduction
If the buttons on your CHI Spin N Curl Rotating Curler (model number CA2288) are not setting the proper temperature, follow this guide to replace the temperature control switch.
The temperature control switch will properly set the temperature on your curler. A faulty control switch will not set your curler to the correct temperature.
Before using this guide, inspect the curler for a faulty heating component. The curler may not be heating up, and the heating component may need to be replaced.
Before beginning, make sure to power off your curler and disconnect from any external power source.
Ce dont vous avez besoin
Use a Phillips #00 screwdriver to remove the screws on both sides of the temperature control switch.
Pop out the control switch.
