Aller au contenu principal
Canon PowerShot G1 X View Finder Zoom Replacement
Ce dont vous avez besoin
  1. Canon PowerShot G1 X View Finder Zoom Replacement, Back Camera Casing: étape 1, image 1 de 2 Canon PowerShot G1 X View Finder Zoom Replacement, Back Camera Casing: étape 1, image 2 de 2
    • To begin removing the back camera casing, unscrew the Phillips screw underneath the panel covering the USB connections on the side of the camera. Use a Phillips Head 00 screwdriver for this screw.
    • Remove the screw located directly beneath the USB cover located in the second photo. Use a Phillips Head 00 screwdriver for this screw.
  2. Canon PowerShot G1 X View Finder Zoom Replacement: étape 2, image 1 de 1
    • After removing the first screw flip to the bottom side of the camera and unscrew the two screws located toward the back side of the casing. The screw on the front side can be left in. Use a Phillips Head 00 screwdriver for both of these screws.
  3. Canon PowerShot G1 X View Finder Zoom Replacement: étape 3, image 1 de 1
    • Now flip to the opposite side of the USB panel screw and unscrew the two screws holding the small speaker cover portion of the camera. Use a Phillips Head 00 screwdriver for both of these screws.
  4. Canon PowerShot G1 X View Finder Zoom Replacement: étape 4, image 1 de 1
    • The last screw is located towards the top side of the back of the camera next to the view finder. Unscrew by using a Phillips Head 00 screwdriver.
  5. Canon PowerShot G1 X View Finder Zoom Replacement: étape 5, image 1 de 1
    • Remove the side panel covering the speaker by gently pulling it away from the camera. You can also use spudgers to create a lever to help remove the panel.
  6. Canon PowerShot G1 X View Finder Zoom Replacement: étape 6, image 1 de 1
    • Remove the back casing by gently pulling. You could also use spudger to create a lever to help pry it off.
  7. Canon PowerShot G1 X View Finder Zoom Replacement, View Finder Zoom: étape 7, image 1 de 2 Canon PowerShot G1 X View Finder Zoom Replacement, View Finder Zoom: étape 7, image 2 de 2
    • Locate the view finder zoom on the back of the camera.
    • Remove the screw using a Phillips #000 screwdriver.
    • Be careful, the viewfinder zoom wheel can fall if the camera is oriented vertically.
    • To remove the viewfinder wheel, pull it to the left and away from the camera.
  8. Canon PowerShot G1 X View Finder Zoom Replacement: étape 8, image 1 de 2 Canon PowerShot G1 X View Finder Zoom Replacement: étape 8, image 2 de 2
    • Locate the viewfinder zoom pin seen in the first image.
    • Orient the viewfinder zoom pin to the same orientation as in the first image.
    • When reinstalling the viewfinder wheel, orient the notch in the viewfinder zoom wheel seen in the second image with the pin seen in the first image.
    • This will allow for the full range of motion of the viewfinder zoom wheel. Improper orientation will lead to a lower range of motion which can cause damage to the viewfinder.
Joseph Cosgrove
Membre depuis le 02/12/17
313 Réputation
3 tutoriels rédigés
Équipe
USF Tampa, Team 20-1, Remmell Spring 2017 Membre de l'équipe USF Tampa, Team 20-1, Remmell Spring 2017
USFT-REMMELL-S17S20G1
3 membres
4 tutoriels rédigés
Un commentaire
Do you guys know where I could get the aperture len flex for this model? Thank you!
Gissela Perdomo - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 3
30 derniers jours : 9
Total : 920
