Introduction
Replacing the function dial is a highly-invasive, step-intensive process that becomes necessary if the function dial has sustained damage due to a crack or internal malfunction.
The function dial refers to the round mechanism on the lower back side of the camera identified by "Func. Set." In this guide, you will learn how to replace the function dial carefully without damaging any essential internal components.
Ce dont vous avez besoin
Remove the three screws on the bottom of the camera using a Phillips-head 00 screwdriver.
Looking at the front side of the camera, there is a port on left side of the camera labeled HDMI.
Remove the one screw on the side of the HDMI port.
Remove the screw on the right side of the view finder on the back side of the camera.
This screw is sometimes hidden inside of the access hole and can only be loosened from the outside of the camera. In order to fully remove it, you will have to partly remove the camera back assembly as the screw head is too large to pass through the access hole.
3 autres ont terminé cette réparation.
2 commentaires
Thank you so much!! I needed to replace the entire rear cover, because Canon doesn't sale just the wheel separately. your guide was the best one I found on the web. I think you ought to make a video of it, I admit I didn't see the "black flip-up" in part 6 so that part (putting the cable back in) was the most aggravating part for me.
But again thank you so much!
Very good guide, the only one I’ve seen so far. Thanks for that>
Philip Knowles
In this guide, the LCD panel has been removed. It is not necessary to do this in order to remove the rear panel. Just fold it open and you can leave it attached.
jnbruin - Réponse
