Aller au contenu principal
Canon PowerShot SD1400 IS USB Port Replacement
Ce dont vous avez besoin
  1. Canon PowerShot SD1400 IS USB Port Replacement, USB Port: étape 1, image 1 de 3 Canon PowerShot SD1400 IS USB Port Replacement, USB Port: étape 1, image 2 de 3 Canon PowerShot SD1400 IS USB Port Replacement, USB Port: étape 1, image 3 de 3
    • Remove the four 2mm Phillips #00 screws on both sides of the camera.
  2. Canon PowerShot SD1400 IS USB Port Replacement: étape 2, image 1 de 1
    • Remove the single 4mm Phillips #00 screw from the bottom.
  3. Canon PowerShot SD1400 IS USB Port Replacement: étape 3, image 1 de 1
    • Remove the front face panel off of the camera.
  4. Canon PowerShot SD1400 IS USB Port Replacement: étape 4, image 1 de 1
    • Remove the rear panel of the camera.
    • The user interface panel, side and bottom panel of the camera may fall down by itself while you are taking the rear panel of the camera.
  5. Canon PowerShot SD1400 IS USB Port Replacement: étape 5, image 1 de 1
    • Remove the 3mm Phillips #000 screw from the top of the camera.
  6. Canon PowerShot SD1400 IS USB Port Replacement: étape 6, image 1 de 1
    • Pry the golden ribbon cable from the motherboard with a plastic opening tool.
    • A screw will be visible underneath the golden ribbon after prying it.
  7. Canon PowerShot SD1400 IS USB Port Replacement: étape 7, image 1 de 1
    • Remove the 3mm Phillips #000 screw from the motherboard.
  8. Canon PowerShot SD1400 IS USB Port Replacement: étape 8, image 1 de 1
    • Use a plastic opening tool to flip up the retaining flap on the ribbon cable ZIF socket.
  9. Canon PowerShot SD1400 IS USB Port Replacement: étape 9, image 1 de 2 Canon PowerShot SD1400 IS USB Port Replacement: étape 9, image 2 de 2
    Outil utilisé dans cette étape :
    • Unplug the small chip from the face of the camera using a pair of tweezers.
  10. Canon PowerShot SD1400 IS USB Port Replacement: étape 10, image 1 de 1
    • Remove the 3mm Phillips #000 screw from the rear face of the camera.
  11. Canon PowerShot SD1400 IS USB Port Replacement: étape 11, image 1 de 1
    • Remove the top panel from the camera.
  12. Canon PowerShot SD1400 IS USB Port Replacement: étape 12, image 1 de 1
    • Pry the golden ribbon cable attached to the USB port using a plastic opening tool.
  13. Canon PowerShot SD1400 IS USB Port Replacement: étape 13, image 1 de 1
    • Remove the 3mm Phillips #000 screw located at the top right of the USB port.
  14. Canon PowerShot SD1400 IS USB Port Replacement: étape 14, image 1 de 2 Canon PowerShot SD1400 IS USB Port Replacement: étape 14, image 2 de 2
    • Remove the USB port.
Faris Rezwan
Membre depuis le 05/21/18
457 Réputation
2 tutoriels rédigés
Équipe
IUPUI, Team S1-G2, Harley Spring 2018 Membre de l'équipe IUPUI, Team S1-G2, Harley Spring 2018
IUPUI-HARLEY-S18S1G2
7 membres
4 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 3
Total : 321
