Aller au contenu principal
Canon PowerShot SD450 Motherboard Replacement
Ce dont vous avez besoin
  1. Canon PowerShot SD450 Motherboard Replacement, Casing: étape 1, image 1 de 1
    • Remove the battery and SD Card from their slots. Leaving these in could cause the battery to ground and ruin the electronics.
    • Unscrew the six screws on the casing. Two are on the bottom as pictured; two more are on each side of the camera.
  2. Canon PowerShot SD450 Motherboard Replacement: étape 2, image 1 de 1
    • Pull the lanyard mount off of the camera using a spudger or your fingers.
  3. Canon PowerShot SD450 Motherboard Replacement: étape 3, image 1 de 2 Canon PowerShot SD450 Motherboard Replacement: étape 3, image 2 de 2
    • Find the line that separates the casing into its two halves. Hold each half separately, and gently pull apart.
    • Note that there is a small metal clip holding the two halves together. It might help to press down on the back half (indicated) while pulling upward slightly on the front half.
  4. Canon PowerShot SD450 Motherboard Replacement: étape 4, image 1 de 1
    • Take hold of the inside of the camera, and gently pull away from the back casing.
  5. Canon PowerShot SD450 Motherboard Replacement: étape 5, image 1 de 1
    • Remove the square, clear, rubber protector from the front of the logic board. This is not necessary to remove, but can easily fall off and get lost during later steps.
  6. Canon PowerShot SD450 Motherboard Replacement: étape 6, image 1 de 1
    • When you reassemble the camera, make sure the switch on the casing matches the position of the switch on the camera internals.
    • The black viewfinder padding can easily fall off the casing. Make sure you don't lose it when moving around parts.
  7. Canon PowerShot SD450 Motherboard Replacement, Motherboard: étape 7, image 1 de 1
    • Remove the LCD cable by gently prying the hinge open with a spudger or your finger. The cable should easily slide out.
  8. Canon PowerShot SD450 Motherboard Replacement: étape 8, image 1 de 1
    • Lift up the metallic-colored clip with the spudger to remove the shutter panel.
  9. Canon PowerShot SD450 Motherboard Replacement: étape 9, image 1 de 1
    • Remove the shutter panel with the spudger, now that the clip is released.
  10. Canon PowerShot SD450 Motherboard Replacement: étape 10, image 1 de 1
    • Use the spudger or your finger to release the orange ribbon from the logic board.
  11. Canon PowerShot SD450 Motherboard Replacement: étape 11, image 1 de 1
    • Pull the ribbon out of the socket using the spudger or your finger.
    • Disconnect the two other ribbons from the logic board in the same fashion.
  12. Canon PowerShot SD450 Motherboard Replacement: étape 12, image 1 de 1
    • Lift up the large green flap by using the spudger to pry up top right yellow edge.
  13. Canon PowerShot SD450 Motherboard Replacement: étape 13, image 1 de 1
    • Pull the flap back with the spudger so that the logic board is exposed.
  14. Canon PowerShot SD450 Motherboard Replacement: étape 14, image 1 de 1
    • Use the screwdriver to remove the three screws on the logic board. Take note that the bottom right screw is shorter than the other two.
  15. Canon PowerShot SD450 Motherboard Replacement: étape 15, image 1 de 1
    • Use the spudger to carefully remove the logic board from behind.
  16. Canon PowerShot SD450 Motherboard Replacement: étape 16, image 1 de 1
    • Remove the detached logic board from the camera.
Chris Wren
Membre depuis le 04/11/10
68 Réputation
1 tutoriel rédigé
Équipe
Cal Poly, Team 25-85, Amido Spring 2010 Membre de l'équipe Cal Poly, Team 25-85, Amido Spring 2010
CPSU-AMIDO-S10S25G85
4 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 10
30 derniers jours : 12
Total : 2,161
