Aller au contenu principal
Canon PowerShot SX60 HS Viewfinder Replacement
Ce dont vous avez besoin
  1. Canon PowerShot SX60 HS Viewfinder Replacement, Back Panel: étape 1, image 1 de 1
    • Make sure to power off the device before completing any more steps.
    • Remove the battery by releasing the orange clip in the battery compartment.
  2. Canon PowerShot SX60 HS Viewfinder Replacement: étape 2, image 1 de 2 Canon PowerShot SX60 HS Viewfinder Replacement: étape 2, image 2 de 2
    • Remove the rubber eye piece by pulling it back.
    • Use the Phillips #00 screwdriver to remove the two 5mm #00 screws located on the side of the viewfinder.
  3. Canon PowerShot SX60 HS Viewfinder Replacement: étape 3, image 1 de 2 Canon PowerShot SX60 HS Viewfinder Replacement: étape 3, image 2 de 2
    • Use the Phillips #00 screwdriver to remove the 4mm #00 screw located on the bottom left of the device.
    • Use the Phillips #00 screwdriver to remove the 5mm #00 screw located on the bottom center of the device.
    • Use the Phillips #00 screwdriver to remove the 7mm #00 screw on the right top corner of the camera, just above the media ports.
    • Use the Phillips #00 screwdriver to remove the two 5mm #00 screws located on the right side, under the media port dust cover.
  4. Canon PowerShot SX60 HS Viewfinder Replacement: étape 4, image 1 de 2 Canon PowerShot SX60 HS Viewfinder Replacement: étape 4, image 2 de 2
    Outil utilisé dans cette étape :
    • Ensure the LCD screen is swung fully to the left before taking off the back panel.
    • Use the iFixit opening tool to pry off the back panel.
    • Don't completely pull off the back panel because there is still a ribbon attached.
    • Use the black spudger to unclip the ribbon located behind the battery compartment. Then remove it using the nylon tipped tweezers.
    • Once the ribbon is unplugged, remove the back panel from the camera body.
  5. Canon PowerShot SX60 HS Viewfinder Replacement, Viewfinder: étape 5, image 1 de 2 Canon PowerShot SX60 HS Viewfinder Replacement, Viewfinder: étape 5, image 2 de 2
    • Use the Phillips #00 screwdriver to remove the two 2mm #00 silver screws located under the viewfinder.
    • Don't pull the viewfinder all the way out because there is still a wire ribbon attached.
    • Remove the plastic housing around the viewfinder by using a black spudger or opening tool to unclip the 3 plastic clips on the sides of the viewfinder.
  6. Canon PowerShot SX60 HS Viewfinder Replacement: étape 6, image 1 de 2 Canon PowerShot SX60 HS Viewfinder Replacement: étape 6, image 2 de 2
    • Unclip the ribbon from the ZIF connector on the viewfinder.
    • Pull out the viewfinder.
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 5
30 derniers jours : 11
Total : 853
