Introduction
Voici un tutoriel pour changer votre module nacelle ou le le boîtier nacelle DJI Mini 3 Pro.
Après avoir changé la nacelle et remis en place la caméra, vous devez re-calibrer votre drone. Il est impossible pour cela d'utiliser l’appli DJI Fly mobile, il vous faut un logiciel supplémenataire. Voici une vidéo explicative de calibrage : https://youtu.be/mu03HWXplM4
Ce dont vous avez besoin
Instructions vidéo
Pour remonter l’appareil, suivez ces instructions.
5 autres ont terminé cette réparation.
Merci à ces traducteurs :
100%
Ces traducteurs nous aident réparer le monde ! Vous voulez contribuer ?
Commencez à traduire ›
9 commentaires
Does anyone have a source for replacing the little rubber gimbal mounts?
Andre Purdy - Réponse
HI there! Does anyone know where I can buy the whole gimbal in USA? I remember seeing it somewhere but cannot find it
gbonilla - Réponse
Go to YouTube and check the link to the gimbal assembly in the description below the video
Arty -
mini 3 pro com port not show on device manegar any help.
Limon Khan - Réponse
Start trembling during flight after a horizontal stop. At the start, I can hear the gimbal noise from trembling (before taking off). I gently touch it, and it stops. I take off and fly a long distance.
If I stop it or it stops it by signal loss, the trembling starts again. if I never stop it and take gentle curves back, it may work. At abrupt stops, it starts trembling. I bring the drone back to me at 1-meter height. I gently touch the gimbal (without landing), and it stops. Then I fly again (if the battery is low, I land, change the battery, and start again, same steps, every time). I will probably buy a new one, so I can send this to repairs - did not check the guarantee yet.
- no problems during climbing up.
- only on horizontal movements and hard stops (release the lever on the controller).
I will try never to release the lever abruptly and never lose signal (a signal lost could be a hard brake, also)
??? Calibration can stop this strange error ????
Dorin - Réponse
