Introduction
Salut tout le monde, dans ce tutoriel vidéo, je vais vous montrer comment démonter votre PS4 Pro, retirer la poussière et remplacer la pâte thermique.
Les modèles de PS4 Pro de 2ème génération sont les suivants : CUH-7200, CUH-7215b, CUH-7216b et CUH-7217.
Ce dont vous avez besoin
Instructions vidéo
Pour réassembler votre appareil, suivez ces instructions.
30 autres ont terminé cette réparation.
Merci à ces traducteurs :
100%
Ces traducteurs nous aident réparer le monde ! Vous voulez contribuer ?
Commencez à traduire ›
4 commentaires de tutoriel
Not all PS4 Pro models look like this one. Some of them have an X clamp rather than the S clamp. You'll need to adjust some of the advice to fit the way your PS4 Pro is built.
commorancy - Réponse Partager
Did this fix, and now my PS4 Pro won't boot. It was working before, but was getting pretty hot (though not overheating) and the fan was running loud. Followed the guide, put it back together, and now it will beep once, show a blue light for a second, and then does nothing. I've tried loosening screws on the back of the APU. I've tried smacking it gently. I've tried a cold start from all residual power being drained. I've ensured all cables are properly connected. Any advice on what could have gone wrong here? I know I didn't fry the motherboard. I work on computers and laptops professionally, but this is just baffling to me.
William Hodge - Réponse Partager
Did you drop the motherboard? It could have broken a solder joint under the APU. If not maybe the 2 prongs on the motherboard that plug into the power supply got bent or ripped off. Or maybe you didn't plug the power supply in. The one-second blue light of death is usually caused by the system getting the 12-volt current from the wall, but not getting the 5-volt current from the motherboard ( the little cable that connects both ). Good luck!
System-Repair-Dude - Réponse Partager
William Hodge how end the story ? your console work again ?
Dan - Réponse Partager
