Introduction
This guide shows how to replace a damaged power cord on the Clarke Floor Buffer 01278A 2016.
You can use regular hand tools for removing fasteners, but using an impact driver will make the procedure easier.
Ce dont vous avez besoin
Use a 3/16" hex key or driver bit to remove the six 23.4 mm-long screws holding the two halves of the handle enclosure together.
Pull the wires connected to the interlock assembly straight out of their connectors.
Use a 3/16" hex key or driver bit to remove the 13.8 mm-long screw securing the power cord's green ground wire to the handle enclosure.
4 autres ont terminé cette réparation.
