Aller au contenu principal
Contixo V8 Internal Speaker Replacement
Ce dont vous avez besoin
  1. Contixo V8 Internal Speaker Replacement, Internal Speaker: étape 1, image 1 de 1
    • Find the edge of the tablet, where the front panel meets the sides. Use the plastic opening tools to pry the panels apart.
    • The back and front of the device can be reattached by lining them up and pushing around the edges. Be sure to do this around the full perimeter of the device to ensure proper connection. You will hear a popping sound; this is the plastic sliding back into place, and is normal.
    • Lift the face of the tablet.
  2. Contixo V8 Internal Speaker Replacement: étape 2, image 1 de 2 Contixo V8 Internal Speaker Replacement: étape 2, image 2 de 2
    • Press the soldering tip to the connection point to detach the speaker from the motherboard. See this guide for information and tips on soldering and desoldering.
    • You will need to reattach these connection points when reassembling your device with the soldering iron. This guide will walk you through how to do that. Be sure to attach the positive and negative wires to the correct points when resoldering the connections.
    • You have now detached the internal speaker and the new speaker is ready to be attached.
phil_sc_03
Membre depuis le 09/08/23
231 Réputation
2 tutoriels rédigés
Équipe
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 3
30 derniers jours : 13
Total : 103
